Tire Dementia
But, while on the drive I convinced myself to supplement the overall rehab with a new set of tires.
Went into a shop near by, Talked to the young man behind the counter about a set of Nokian Rotiiva they had on the sales floor. I asked if they might have a set that would fit my truck. The set on the floor had 285/75/16 on them and I knew stock on my rig was a 265/75/16.
The sales gent. Exclaimed that the 285's would fit just fine. Well, I told him I was interested, but before the truck rolled into the shop I asked a few questions regarding load rating and such. He informed me that moving up in size from a 265 to a 285 would take care of the needed weight handling ability needed for the rig. I questioned that to the point that he went and found a 265 to compare load ratings to. I guess looking it up on the net wouldn't work on the in house system,idk.
At any rate, I noticed the some what lower rating in comparing the two, but with a bit of convincing, started the install.
The install went well( they forgot to ask what side out, but got em all the same). I had asked that they not weight the outer rim edge to keep the clear coat intact, so they sticky weighted behind the face on the inner rim, and hung weights on inner rim edge. All fine and good till I took the truck to 60 on the highway.
At about 60, I got this high pitched vibration through the steering wheel. It continued to about 70, then was gone. Only to return, once returning to 70 back down to 60.
The next day I took the rig back to the tire shop and asked the Manager to take it for a drive with me. He confirmed the vibration, and had the crew match-mount the tires and rims. A very long process of matching the heavy parts of the tire and rim opposite each other. This time weighting on both inner and outer rim edges.
After hours of balancing I asked to jointly test drive with the manager again, and the vibration was still there.
He suggested lowering the air pressure to 50 in front and mentioned that if it didn't solve the issue he would swap another tire type. So, I'm not sure but I think I might have to go there. I lowered the pressure to 50 and I still get the issue.
The rims are under sized for the 285's. The tread is pulled up on the edges. a good inch width, on each side of tire doesn't hit pay dirt. It might as they wear but? Could this be a major contributor to the vibration.
Just how much trouble do ya think this constitutes.
Honestly I don't look forward to going back to the shop but if you all concur, off i go
Thanks for the read.
But then again, you probably didn't have any vibration with your old tires.
I hope you get this resolved.
The rig had no vibration of the sort with the old coopers on her. While it could have been masked by the two old tires in the rear before the change over that had lateral(on one) and vertical(on the other) runout issues. The front felt solid and had no vibration through the steering.
After a bit of looking around I do see that many makers offer a 285 in a E rating
. I imagine the new tires she has on, has cost around 1600lb of load capacity? I don't tow much more than gear and a 2 place snow-machine trailer, but the end result if in a accident might prove a Insurance nightmare. <-- not meaning to add to the overall issue at hand tho.
Maybe they just need some breaking in. Once the tread wears flat maybe all will be as it should be.
One note tho , they did use the same balancer both times they tried addressing the vibration. For the vibration to be in such a narrow speed range seams odd?
