high idle
Old Nov 9, 2014 | 02:04 PM
Gary67's Avatar
Gary67
high idle
When i come to a stop the engine races at first, then will settle down and almost die.99Ranger
Last edited by Gary67; Nov 9, 2014 at 02:05 PM. Reason: no details of the model and year
Old Nov 9, 2014 | 11:11 PM
Mikeman's Avatar
Mikeman
Might be the idle air control valve (IAC). If you google "Ford IAC", "how to test IAC", etc. you should be able to find plenty of information and youtube videos. Keep in mind that the IAC is similar across other Ford models, so something you see for an F150 or Explorer would most likely apply.
Are you getting any codes?
Old Dec 2, 2014 | 08:44 AM
Gary67's Avatar
Gary67
iac
Replaced it but now it idles very low and dies constantly
Old Dec 2, 2014 | 10:22 AM
Backwoods351's Avatar
Backwoods351
What engine do you have?, could be a dirty or bad maf sensor. Had a similar problem on a customer ranger and that was the fix.
Old Dec 3, 2014 | 10:42 AM
greenpus's Avatar
greenpus
Originally Posted by greenpus
There is a tech bulletin ford put out. I can't rememeber the number of it.
It concerns the 98-2000 rangers. High idle issues when replacing the IAC don't fix it.
Basically the connector on the TPS is jacked up and Ford recommends buying their $80 kit to fix it. The kit has a new connector which you splice into the old cable harness for the TPS.
I had the same issue every 6 months and would replace the IAC for high idle and it always came back anywhere from 3 months to 6 months. I also noticed a pattern. The high idle always seems to come about during wet or humid weather conditions.
After reading the tech bulletin I decided to clean the connector on the TPS and the connector that plugs into the TPS with electronics cleaner. While the connector was wet with the cleaner, I put the connectors together and took them apart several times to help clean the contacts/pins. I let the connector dry for a few minutes and then stuffed the connector with dielectric grease to help prevent corrosion on the pins. Put everthing back together and fixed. No idle issues anymore. After doing this your idle trim might be out of wack but drive it for a couple of days and let it relearn the idle trim. Don't bother unhooking the battery to do this. Just drive it.
rj1983
May 3, 2017 04:04 PM
nat13_3
Jul 22, 2009 08:08 PM
kjg26
Feb 10, 2006 01:10 PM
Steve01
May 28, 2003 09:28 PM
93bigbronco
1978 - 1996 Big Bronco
Feb 23, 2003 11:42 PM
