Windshield Washer Sprayer
Old Nov 9, 2014 | 08:50 AM
qman's Avatar
qman
Anyone ever do anything to upgrade the little steel sprayer hoses? It takes too many sprays to clean off the windshield. Instead of one spray that covers the entirety in front of driver or passenter, you have to keep spraying until the wipers get it all washed off from the middle outward.
The kid of a friend of mine bought some generic sprayers and zip tied them on. They work but look like crap. I just figured someone here got tired of it and did something to fix it the right way.
Old Nov 9, 2014 | 09:09 AM
orich's Avatar
orich
I'm not willing to drill any holes in my hood for the multi-sprayer heads..
But have thought about it a few times.
Orich
Old Nov 9, 2014 | 02:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Take the jets off, soak 'em in white vinegar for several hours. They're probably clogged up with scale caused by using tap water instead of distilled water.
Also suggest replacing all the rubber hoses.
Old Nov 9, 2014 | 03:36 PM
HIO Silver's Avatar
HIO Silver
IIRC, there was some make/model out there with sprayers mounted on the wiper arms.
Be creative... swamp buggy racers rig up irrigation nozzles/sprayers. Make sure you have a pump and reservoir big enough to suit your needs.
Old Nov 9, 2014 | 08:14 PM
orich's Avatar
orich
Ha, I came across some of those aftermarket arm sprayers at the loco flea market for a $buck someone was selling.
Looked kind funky on a 87 Camaro, but did wet the full rang of the wiper arm. Did not leave them on their..
Orich
Old Nov 10, 2014 | 01:34 AM
CharlaineC's Avatar
CharlaineC
I found carefully bending the sprayer to aim properly helps as well as cleaning them out.
Old Nov 10, 2014 | 05:30 PM
qman's Avatar
qman
Mine aren't clogged. They spray like mad. I don't use water. I used windshield washer fluid.
I just don't like the single spray stream into the middle of the windshield.
Old Nov 11, 2014 | 04:35 PM
JEFFFAFA's Avatar
JEFFFAFA
81/91 Econolines had the sprayers in the arms. Those would be too long though. I could swear I've seen "clip on" sprayers somewhere. LOOKING.......
Old Nov 12, 2014 | 03:22 PM
doug51f1's Avatar
doug51f1
Has anyone ever tried squeezing the tip of the tube with pliers to make the spray fan out? (I'm going to let someone else do it first) ;-)
Old Nov 12, 2014 | 04:46 PM
JEFFFAFA's Avatar
JEFFFAFA
BINGO!
I knew I'd seen factory clip on washer nozzles in the past. Finally got a chance to pick up the search for them.
D3AZ17A602B....R/H & L/H.
75/79 Econolines.
73/79 Full Size Ford Car.
74/76 T-Bird.
D5OZ17A602B..L/H........D3AZ17A602B...R/H.
75/76 Torino.
77/79 LTD II (MIDSIZE)
77/79 T-bird.
Old Nov 14, 2014 | 12:47 PM
qman's Avatar
qman
What do they clip on to?
Old Nov 14, 2014 | 02:57 PM
JEFFFAFA's Avatar
JEFFFAFA
They clipped on to the wiper arm. I can't post Ford pics like Bill can. Once he catches this I'm sure he will for you.
Old Nov 14, 2014 | 08:52 PM
orich's Avatar
orich
They fit in the underside of the wiper arm Dodge vans also have them.
orich
Old Nov 15, 2014 | 10:16 PM
HIO Silver's Avatar
HIO Silver
orich
Found one.... a 2000 Chevy Suburban (and likely its kin)
Here's a short, three-minute video:
The passenger side has three nozzles and the driver side wiper has two.
Gentlemen, start your salvage yard hunts!
Old Nov 17, 2014 | 12:17 PM
qman's Avatar
qman
I have a 94 Chevy Suburban and the rear window sprayer is one of those.
Ricohman
Jun 12, 2018 06:07 PM
Krabill
Jan 26, 2018 06:21 PM
JoeyCap
Feb 25, 2015 10:59 AM
arrowheadfred
34
Jan 17, 2011 01:30 PM
Zoltrix
General Automotive Discussion
Dec 12, 2004 09:11 PM
