Fuel Pressure Regulator Blue spring problems
Old Dec 21, 2014 | 12:20 PM
Pat Taugher's Avatar
Pat Taugher
So little update.... i took apart everything, found that little oring and put a little assembly lube on it... and put it all together.... it could be just a placebo effect, but with the oring i noticed the truck cranks over faster... idk if it is related or not. but i got the oring in... and put everything back together
Old Dec 21, 2014 | 01:44 PM
mustang_309's Avatar
mustang_309
Good deal and it will add piece of mind that you are not starving the injectors of the fuel pressure they need. When I helped a friend of mine do his blue spring I didn't install that oring and I could hear the fuel by-passing the black bushing, almost like a whirring noise, took it apart and installed the oring and whirring was gone. One way to look at fuel pressure is the fuel inside the injector acts like a shock absorber of sorts and if the pressure gets too low it can allow over drive of the injector allowing the pintle to contact the body of the injector causing damage.
Old Dec 21, 2014 | 01:54 PM
Pat Taugher
I have heard stories about bending the spring... When I pulled it off it was fine and think it put it back just as fine... But how would I know for sure?
Old Dec 21, 2014 | 02:04 PM
mustang_309
I would think low fuel pressure and you would likely hear fuel by-passing the regulator with the key on and the fuel pump running. But im sure if you didn't bend it the first time I am sure you didn't bend it this time.
mastersativa
Mar 12, 2019 04:37 AM
WatsonR
May 19, 2014 08:14 PM
waumpuscat
Oct 23, 2011 10:49 PM
loopsy
Apr 12, 2011 06:17 PM
Gmcbuffalo
Jul 14, 2010 08:33 PM
