fuel pressure question
Old Oct 23, 2011 | 09:12 PM
waumpuscat's Avatar
waumpuscat
After installing my Edge Insight on my 05 I am getting readings of 47-48 on start up and regular driving with readings at 45-48 and sometimes below if I accelerate quickly. At WOT I have seen it drop below 37, so I have been driving very conservatively until I install the blue spring. My question to those with more experience is will the blue spring likely cure this issue or do I have other problems? I might add that I am the original owner of this 44000 mile truck and as far as I know it runs great but I am on a mission to prevent as many high dollar repairs as is possible so please offer any and all suggestions.
Old Oct 23, 2011 | 09:24 PM
BLADE35's Avatar
BLADE35
do the blue spring soon
it should bring up the fuel pressure
How about fuel filters they been hanged in awhile
Old Oct 23, 2011 | 09:31 PM
waumpuscat's Avatar
waumpuscat
Benny, absolutely. I changed both just a thousand miles ago and have began using additives such as the optilube and I picked up some diesel kleen cetane boost today.
Old Oct 23, 2011 | 09:37 PM
BLADE35's Avatar
BLADE35
IIRC trhat spring is good for at least 10 psi
heres a good read with pics on that blue spring
just thought I would post it up it is a peice of cake though
Blue Fuel Press Spring install
http://www.thedieselstop.com/forums/...ctures-278882/
go really light on the go pedal till you get the spring in under 45psi is bad
Old Oct 23, 2011 | 09:54 PM
waumpuscat's Avatar
waumpuscat
Check on that going easy on the go pedal. I watch those gauges pretty close. Can u speculate as to what I can expect after the blue spring install?
Old Oct 23, 2011 | 10:14 PM
Snuggyworm's Avatar
Snuggyworm
after the blue spring install, u should have a little more "giddy up and go". u will notice tat difference. also, ur startup will definitely be much more responsive.
Old Oct 23, 2011 | 10:16 PM
BLADE35's Avatar
BLADE35
IIRC around 10 psi or so
Old Oct 23, 2011 | 10:21 PM
waumpuscat's Avatar
waumpuscat
10psi would likely not keep me above 45 at wot. Is there something else that I should so if that is the case?
Old Oct 23, 2011 | 10:25 PM
BLADE35's Avatar
BLADE35
Just pull it apart and do it see what you find the plunger might cocked or something
it maybe alittle more than 10 psi to kinda a guess everyone diff
let us know what happens
Old Oct 23, 2011 | 10:49 PM
waumpuscat's Avatar
waumpuscat
Will do Benny, thanks for the help
brian42
May 13, 2015 11:15 PM
RideDiesel88
Oct 15, 2012 12:15 PM
WH 6.0
Aug 6, 2012 09:05 PM
2006powerstroke90
Oct 29, 2011 02:30 PM
busdriver47
Sep 2, 2011 10:10 AM
