37 inch tires. What gears.
I have a 2005 f250 4wd with an 8inch lift And 37 inch tires. I currently have 410 gears.
What gears are you guys running with 37's. What's your rpm at 65. Mpg? Did you notice a difference in power?
One more question. Will 4.88 gears fit in the front and rear without needing anything else like a new carrier?
If your speedo/abs system isn't corrected for the larger tires you will not get accurate mpg figures.
A set of 4.88 gears with 37s will yield an effective ratio of around 4.22 with stock tires. A set of 5.13 gears will have an effective ratio around 4.44 with stock tires. I'd say 4.88s will work very well, if you do a lot of heavier towing the 5.13s may be worth looking at harder.
nissanjon
02-02-2000 08:33 PM
