Master Cyl.Hydroboost
Old Nov 6, 2014 | 02:41 PM
yasky69's Avatar
yasky69
So I take my new (for me but used) 2007 F350 to the local Ford Dealer to have the oil changed, along with fuel and water separator filters. I even added some Archoil 9100 since it treated my 03 so well. Since I had no history of the last change I wanted to do it right away.
While its on the lift he notices a leak near the hydroboost and quotes me $650 for the repair. I think there on crack...but that's my opinion.
Anyways I look at it and I see a leak at one of the connections under the Master Cyl. Its the connection closest to the firewall. My question is there a oring in there that can be replaced or will I need to replace the entire part?
Old Nov 6, 2014 | 04:29 PM
69cj's Avatar
69cj
I'm not trying to be a smarta**, but if you have no clue, I'd let a pro do the job. Brakes are not the place to learn on your own if you have no mechanical back ground. Your steerimg can also be involved because of the hydroboost system being an integral part
Old Nov 6, 2014 | 04:56 PM
yasky69's Avatar
yasky69
Thanks for your input.
I was simply trying to find out before I take it apart. I'd rather have the parts on hand prior to doing so. So if I don't know if there is one or not, figured it be an easy question for someone that has had it apart before. Or maybe it would be a recommendation from the senior forum users to just replace it.
Old Nov 6, 2014 | 05:40 PM
WatsonR's Avatar
WatsonR
I can look on my CD after I get home. Wouldn't think this is to hard, probably a tapered fit and a little Teflon tape may be needed or just snug it up. A crack in it would appear as a dark line, if then I'd replace it.
$650 is a lot to guess at and he wouldn't be doing it with my $$$ either.
Old Nov 6, 2014 | 06:32 PM
WatsonR's Avatar
WatsonR
Doesn't look like any o-rings in the line that I could see on the drawing for the hydroboost or the lines. Just be sure to get the air out.
Old Nov 7, 2014 | 03:49 AM
Yahiko's Avatar
Yahiko
Brake fluid leak or Power steering fluid>
DO NOT Use tape on any of the lines. If that stuff gets into the brake system your hosed.
The line if not sealed by an O-ring have a teflon seal. The tape had a bad habit of
going places where you don't want it like a control valve and orifices.
Flare lines seal on the flare face not the threads anyway. The power-steering
have O-rings or the teflon seals.
Check to make sure all the nuts are tight. Not gorilla tight. But good and sung.
If you don't know what your doing like 69cj said take to a pro. Better a little
less money in the pocket then having to be put 6' under do to a brake failure.
Sean
Old Nov 7, 2014 | 06:03 AM
yasky69's Avatar
yasky69
I'm aware of having to bleed brake lines and how to bench bleed a master cyl.
Anytime you open a line your allowing air into the system. I'm not a expert mechanic but have wrenched for many years on all the other cars we've had. Primarily the vette I've owned for the past 12 years.
Anyways I'll just open it up and see what exactly type of flare is used. It is brake fluid that's leaking. A couple of days ago I marked the resevoirs of both brake and steering. Its the brake fluid level that has dropped.
I may just take the easy route out and throw a new master cyl on.
Old Nov 7, 2014 | 06:17 AM
Yahiko's Avatar
Yahiko
You can get the master separate from the hydroboost.
To do a full bleed it takes a bit of fluid and if it been
in there for a while it might be a good idea to flush out
all the old fluid and start fresh.
Sean
Old Nov 7, 2014 | 07:47 AM
Per4mance's Avatar
Per4mance
These brakes a sensitive just like a C 3 Vette, get the old out and use dot 4 brake fluid.
Old Feb 24, 2015 | 04:15 PM
kbf1961's Avatar
kbf1961
Im also looking for info. Between the hydroboost module and the master cylinder there is a joint that joins the two, mine is leaking power steering fluid????? O ring ? or do I need to replace the whole module? Does anyone have a procedure for replacing this module, part # etc???
GotThreeOfThem
Sep 1, 2012 11:53 AM
clhart426
13
Feb 26, 2010 09:26 PM
nsaikia
Sep 26, 2005 08:53 AM
Jstlikeb4
1978 - 1996 Big Bronco
Nov 29, 2004 01:32 PM
Billy4416
Nov 21, 2004 07:04 PM
