1978 - 1996 Big Bronco
Master Cylinder leak
Old Nov 28, 2004 | 02:54 AM
Jstlikeb4's Avatar
Jstlikeb4
i was getting some regular service on my 1988 bronco before i drive it across country from CA to SC and they told me that the master cylinder is leaking a little. do yall think that this will be a major problem for driving across or should it be alright?
Old Nov 28, 2004 | 09:14 AM
F150'89's Avatar
F150'89
If the master cylinder is leaking the get it replaced before your trip. You don't want to lose your brakes while going down a mountain road!
Old Nov 28, 2004 | 12:51 PM
kameronth's Avatar
kameronth
I would not recommend it , although my master cylinder had been leaking fo a year until I finally decided to replace it.
Old Nov 28, 2004 | 04:37 PM
JBronco's Avatar
JBronco
Once a master cylinder starts to leak, it usually goes downhill FAST. Like within a couple of weeks until you have no brakes. Kameronth's year is not typical. Replace it now, it is very easy. $50 and a couple of nuts to R&R and you are done. Bench bleeding is the biggest PITA of the whole job. But don't get too hung up on the bench bleeding - the last one that I replaced never seemed to bleed on the bench, and I got tired of pumping it, so I just stuck it on the truck to see what would happen - it worked fine. Just give it a few pumps on the bench to get the major air out and install it. If it does not work you can always bleed it on the truck.
Old Nov 28, 2004 | 06:12 PM
kameronth's Avatar
kameronth
I also have an 88. Mine is a plastic one. They should be the same. Mine was easy to install, just bleeding it got old but it did work.
Old Nov 28, 2004 | 11:46 PM
ANdrewdrice's Avatar
ANdrewdrice
where is it leaking, might just be an o-ring problem; on the bottom of the reservior.
Old Nov 29, 2004 | 01:32 PM
JBronco's Avatar
JBronco
Is it an external leak or an internal leak? I was thinking that he meant an internal leak; if it is external and just leaking fluid out, that should be easy to fix. You can fix an internal leak as well, they are not hard to rebuild if you get the kit. But m/c's are cheap so I generally just replace the whole thing.
