Engine ID
Old Nov 6, 2014 | 12:26 PM
Diesel_Brad's Avatar
Diesel_Brad
Engine ID
How do I I.D. what year engine I have?
Back in 94 I bought this 429 from a guy who pulled it from a LTD.
I rebuilt it and put it in my 80 F350.
But now I forget why year the engine is. IIRC it is a 71 or 72. But how can I tell for certain
Old Nov 6, 2014 | 02:40 PM
cbakker's Avatar
cbakker
Start with the casting numbers. Post them and we'll try our best.
Old Nov 6, 2014 | 06:51 PM
Diesel_Brad
OK, Where should I be looking for casting numbers?
Old Nov 7, 2014 | 12:11 AM
85e150's Avatar
85e150
Best I can tell, the numbers are in the valley. Some pics show them on the sides of the block, but the date code is in the valley best I can tell.
Do you need to know so you can get parts or for other reasons?
Old Nov 7, 2014 | 04:28 PM
Diesel_Brad
In the valley? Like under the intake?
I want to know if it is a 10:1 0r 11:1 compression ratio
Old Nov 8, 2014 | 01:03 AM
85e150's Avatar
85e150
Yes, under the intake.
I just found this. Scroll down regarding the date code on the passenger side of the block in front.
http://429mustangcougarinfo.50megs.com/decoding.htm
IF it's a '71 Thunderjet, it's 11, but I thought I heard they were 11.3 in the day.
Lots of casting number info here for 429s.
Kelly hotrod - Ford Engines Page 3
More discussion. Note one comment about the CR for the 2bbl being advertised at 10.5 despite the same pistons and heads. It was a "Premium Fuel" 2bbl as found in Mercurys.
https://www.ford-trucks.com/forums/2...hunderjet.html
Ford offered a 2bbl motor for cheapskates like my dad, and for people with insurance companies that became ill over 4bbl carbs.
Old Nov 8, 2014 | 01:34 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Casting number on block same 429/460.
Block casting number prefix: C8VE = 1968 / C9VE = 1969 / D0VE = 1970.
Block casting number: D1VE-6015-A - AB - AB1 - AB2 = 1971/73 429; 1971/78, some 1979 460.
Old Nov 9, 2014 | 11:09 PM
Torky2's Avatar
Torky2
IIRC, my 1970 460s had the block number hidden by, or just above the starter.
For cylinder head prefixes, look between cylinders 2 & 3, and 6 & 7 by the exhaust manifolds just below the valve covers. That's what I remember, anyway.
A 1971 429/460 would still be high compression ~ 10.5:1. For 1972 compression is way down, and timing is retarded via timing chain and sprockets (the crank sprocket teeth vs. keyway position).
Old Nov 18, 2014 | 11:47 PM
mdh1701's Avatar
mdh1701
The ONLY 429s that ran 11:1+ compression was the CJ/SCJ, all Thunderjet 429's 68-71 are 10.5:1 whether 2 or 4 bbl carb. 460 Lincolns in this year range are also 10.5:1. All BBF dropped to 8:1-8.4:1 from 72-on depending on year, head, piston etc.
76f350spercamprspeal
Apr 2, 2019 06:26 PM
karjunkie
Aug 22, 2013 02:59 PM
j_rok13
Jan 8, 2008 07:11 PM
skeleton
Flathead V8 & Flathead 6
Jul 10, 2002 07:38 PM
topo4u2
May 21, 2002 09:18 PM
