Help Numberdummy!!
Hi, new here. Second thread but love reading everything and am somewhere in the mid hundreds of the over 1000 pages! I have 2 66 f250s (I was told) and would love to know for sure if you would be so kind to help. The bottom truck numbers have me confused especially. Sorry for the lack of pics but I haven't figured it out yet. info is:
F25YR817575 129 BV F250 C81 A 24 07500 172 4000 73 F25BK891001 129 M F253(?) 481 F 24 06000 150 3600 73 Thanks, John |
This will be interesting. From what I know the sequence numbers for both trucks puts them in 1966 (732,001 thru 914,000), but the F253 doesn't show as a valid model code until 1967. I know those tags are very small so some have mistyped or misread some of the info on them before. Are you certain about the info? If so, ND to the rescue. Lol.
Originally Posted by Jfitzgerald
(Post 14798752)
F25YR817575 / WB: 129 / COLOR: BV / MODEL: F250 / BODY: C81 / TRANS: A / AXLE: 24 / MAX GVW LBS: 07500 / CERT NET HP: 172 / RPM: 4000 / DSO: 73
Y = 352 2V R = San Jose CA Assembly Plant. 817575 = 1966, assembled February 1966. 129" Wheelbase. BV: B = Caribbean Turquoise / V = :-huh (not listed for 1966). F250 2WD, 7,500 lbs. GVWR C81: C = Medium Green Crush Vinyl & Medium Green Cody Pattern Woven Plastic / 81 = 81B Custom Cab. A = New Process 435 4 Speed Manual Transmission. 24 = Dana 60 Rear Axle / 4.10-1 / No Limited Slip / 5,200 lbs. Rear Axle Capacity. 7,500 lbs. Gross Vehicle Weight Rating. 172 net HP @ 4,000 RPM 73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from. F25BK891001 / WB: 129 / COLOR: M / MODEL: F253 / BODY: 481 / TRANS: F / AXLE: 24 / MAX GVW LBS: 06000 / CERT NET HP: 150 / RPM: 3600 / DSO: 73 B = 300 1V I-6. K = Kansas City MO Assembly Plant. 891001 = 1966, assembled July 1966. 129" Wheelbase. M = Wimbledon White. F253 = F250 2WD, 6,000 lbs. GVWR 481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab. F = Borg Warner T-18 4 Speed Manual Transmission. 24 = Dana 60 Rear Axle / 4.10-1 / No Limited Slip / 5,200 lbs. Rear Axle Capacity. 6,000 lbs. Gross Vehicle Weight Rating. 150 net HP @ 3,600 RPM 73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from. |
Thank you, thank you!! That helps a bunch and clears up things for me. I am selling the one with the 300 i6 and wanted to make sure I new what I was selling. Hoping to use the proceeds to finish the 352 rebuild in the other one. Really big thanks
Interestingly, the truck that is painted Caribbean turquoise is two-tone the other tone probably the V, is a cream color. But underneath the cream color you can see the Caribbean turquoise in wear spots which I thought was strange. The paint job looks very clean though and of the same timeframe as the Caribbean turquoise so I'm not sure what that's all about
(Post 14799460)
There is no V code for any 1966 truck, Bronco or Econoline. V = 1966 FoMoCo Passenger Cars: Emberglo Metallic which resembles burnt copper. Caribbean Turquoise was tu-toned with white, could be: C = Pure White / M = Wimbledon White |
1 Attachment(s)
No, it looks like an M as I can see the legs extending down into the black.
Embarrassing. I couldn't see the forest for the trees!! I see it now plain as day. Thanks everyone. Would they have painted over the green with the white to get the two-tone?
Originally Posted by Mr. Magoo
Here is the V, it looks like that to me. :confused:
BM: B = Caribbean Turquoise / M = Wimbledon White. |
(Post 14799827)
Yes. My tu-tone truck is gold under the areas that were painted white. Same deal. . |
This is great as shows the value of pics. As soon as I zoomed in on the V, I saw the M.
Me too! But it took someone else zooming and a post here!
1 Attachment(s)
I'm still curious about the 253 for the Model Code. Here's what the MPC says on page 45 of text manual. Maybe we'll never know....
Attachment 109024 . |
