Meltdown between starter relay and GP controller
Old Apr 4, 2015 | 11:54 PM
madpogue's Avatar
madpogue
I thought the '87-'91 trucks had the same awful clutch switch as the '83-'86, that funky thing on the left side of the pedal arm, rather than the switch on the pushrod.
Old Apr 5, 2015 | 10:47 AM
bigfish6025's Avatar
bigfish6025
Thats so funny- the 4 or so clicks I would hear happened in such even rhythm I thought it was normal.
The buzz sound I'm hearing/sometimes not hearing- not too worried about it, but just to clarify that the sound seems to come from in the cab and it is on as long as the wait to start light is on. Up until now I just always took it to be an auditory 'wait to start' indicator. Do our trucks have that?
I'll probably bypass the clutch switch once it becomes too much of a PIA.
Old Apr 5, 2015 | 12:05 PM
madpogue's Avatar
madpogue
No, there's no audible WTS indicator. Some cheap relays make noise; that's probably what you're hearing.
Old Apr 5, 2015 | 06:42 PM
typefour's Avatar
typefour
The connector heating will raise the current enough to burn the fusible links. Common. The bad connector will change the action of the controller so you would here clicking as it goes into afterglow cycling , thinking it has cycled properly. The clutch switch is a pain. No more to say about that.
creativecars1
Jul 17, 2019 04:06 PM
B.Les
18
Mar 21, 2017 02:39 PM
Dieseldan7.3
Nov 6, 2005 09:49 PM
royzell
Feb 22, 2005 09:00 AM
Fordhound
Apr 7, 2004 08:18 AM
