Sponsored by: Real Truck
Driveline vribration
Old Jun 16, 2017 | 12:41 PM
jakgod3's Avatar
jakgod3
02 CCSB, and I have a vibration in my driveline that's starting to drive me nuts on my commute every day. I can feel it faintly starting at about 45 mph, whether the torque converter is locked or unlocked. The vibration peaks at about 60 mph and goes away at about 65+. My u-joints are all moog and grease them every oil change (about 120k on them now). At this point I suspect the carrier bearing, yokes, or even u joints but theres not much play. However the rubber around the carrier bearing is in rough shape and dry rotting. I'm curious if there's a test I can do to find the culprit. Thanks in advance
Old Jun 16, 2017 | 02:49 PM
Dasher400's Avatar
Dasher400
Double check your u joints, but if the carrier is as you say all dry rot and crusty, then my money is that is your culprit. Just grab the drive shaft at the carrier and give it a wiggle, if there is any slop in the carrier its got to go.
endobear
Nov 17, 2014 11:19 AM
gladesteen
Nov 4, 2008 12:13 AM
BENG0924
Sep 6, 2008 01:46 PM
99turbo
Feb 24, 2005 10:50 PM
85 F-350CrewCab
Sep 12, 2004 11:00 PM
