Electrical Issue/Question
Well the Pitman arm is finally replaced and I am back on the road. I wanted to install a kill switch to the power wire to my HEI distributor but oddly noticed while tracing the wire tha it showed continuity to ground when the key was off. With the key on it has power obviously. In the pictures anywhere I have the red probe shows continuity on ground, including the ground post on the battery, chassis ground, positive cable to the starter but not the battery and one wire coming into the selenoid has continuity and one post doesnt. In other words with both of the selenoid wires off the left post has continuity but not its wire vice Versace on the other side.
Does this just mean I have a ground fault on that circuit? Appreciate any electrical expert advice on this:-)
Ida Know
Second pic,
That is ground for the solenoid
Third pic,
The starter has very low resistance, probably less than 2 ohms.
Forth pic,
That's one side of the starter solenoids coil. It too will be a very low resistance as it's just a coil of wire.
Fifth pic,
That provides full battery voltage to the ignition when cranking and may well be the same wire as in pic one.
Sixth pic,
erm, that's the ground post...
Michael
In the pictures, the first pic with the black probe is the positive wire to the distributor and this stayed connected for all the other pictures. The red probe was then touched to the other points and I heard the audible beep on the voltmeter
Depending on the meter, the continuity range can beep at anywhere from a few ohms to 1.5K ohms.
I don't know what the wiring inside the distributor looks like but suspect at some point, it involves a coil of wire used as a pick-up. It's very likely that you are seeing a low resistance through that coil that is triggering the continuity beep on your meter.
A resistance of 1000 ohms to ground at that wire will only draw .012 amps when 12 volts are applied yet could still easily trigger a continuity beep. That and if that wire goes straight to the key, anything else that's powered by the key in run position will be in parallel, reducing the resistance in the circuit even further and making it even more likely that your meter will beep.
I'd not worry about it if it's been running 'till now.
Michael
Mine used to do that until I noticed and corrected that missing body ground.
