Front End Bounce
Old Jan 5, 2015 | 06:51 PM
DeeDubz's Avatar
DeeDubz
Originally Posted by FordService
Any news from the dealership today, DeeDubz? I'll keep checking in for your updates in case you need my help.
Crystal
None yet Crystal, Ill keep you guys updated. I planned on not having my truck for a few days.
Old Jan 5, 2015 | 08:23 PM
DeeDubz's Avatar
DeeDubz
Ford just called, says they can't really find anything wrong with the truck... so far. However the service writer told his techs they need to continue to investigate.
Old Jan 5, 2015 | 09:06 PM
Randy Klauk's Avatar
Randy Klauk
Is this an issue/problem on 2wd, 4wd or both? Has anyone experienced this while towing a travel trailed or 5th wheel trailer? I put more than 90K miles on my 2004 F250 cc long bed and never experienced a problem with the front end. All front end and steering components were stock and original when I traded it in with about 138K miles on it, even had original shocks. Is this a problem that showed up when the new (6.7) engine came out?
I understand I'm no help here but after all the problems I had with my 6.0 (and much money spent) I'm hoping not to have any inherent problems with my new truck.
Randy 2014 F250 Lariat CC LWB
Old Jan 5, 2015 | 10:35 PM
Chad149's Avatar
Chad149
" Death Wobble" can happen on any solid front axle equipped vehicle, and is no more likely to occur on your currant truck than your last one. If it does occur a though inspection of the steering componets and tires normally finds and resolves the issue. Installation of a cheap leveling kit can also cause a reduction of caster angle, causing it as well, but not relavent here.
Old Jan 6, 2015 | 09:13 AM
FordService's Avatar
FordService
Official Ford Rep
Thanks for the update, DeeDubz. You may want to consider taking your tech along for a test drive so you can try to replicate what you've been experiencing.
Crystal
Old Jan 6, 2015 | 02:39 PM
DeeDubz's Avatar
DeeDubz
Update, Ford called around 10 am told me that they are replacing the steering stabilizer and my truck is out of alignment again... The service tech was super nice over the phone and told me that they're going to get this problem fixed. He mentioned my tires will need to be replaced down the road but he's not convinced that its a tire issue. The steering stabilizer wasn't initially replaced my first trip to ford last month. He told me that it didn't meet the replacement under the warranty because it wasn't broken or leaking fluid... But he noticed that its out of spec and needs to be replaced. He spoke with his manager and they both agreed to replace it under the warranty. I asked if I would be paying out of pocket and he advised me not to worry about paying for anything at this point. Things are looking good, might be getting my truck back in a day or two.
Old Jan 6, 2015 | 06:04 PM
watchluvr4ever's Avatar
watchluvr4ever
Great news! I hope that fixes all of your problems.
Old Jan 8, 2015 | 09:07 PM
DeeDubz's Avatar
DeeDubz
My truck is back home, I was able to pick it up this morning. Very happy with the staff at Redlands ford they did a great job. The truck was cleaned inside and out. Awesome job ford, Im a happy / proud Ford owner.
Old Jan 9, 2015 | 07:02 AM
BigBlueOx's Avatar
BigBlueOx
What parts did they replace on the first trip to the dealer?
Having this happen to me in a past truck and finding the shock bushings SHOT I'd say it's most likely going to be either the front shocks or track bar bushings. The wobble I expirienced wasn't so much the steering as the axle hopping up and down alternately. Although it does violently shake the steering wheel. The only way to truley test the shocks are to mark them at their normal position, take them out of the vehicle (without turning them upside down or sideways and try to keep them at normal ride position) and see how much "free travel" they have before feeling resistance.
Oh and my .02
Old Jan 9, 2015 | 08:33 AM
FordService
Official Ford Rep
That's what I like to hear, DeeDubz! I'd like to document your feedback about this awesome experience in our system. To get started, send me a PM with your full name, best daytime phone number, dealer info, and any specifics you'd like me to include. I'll do the rest.
Crystal
Ford ST
Aug 8, 2019 06:08 PM
f350girl
Feb 28, 2011 09:45 PM
John with beastly 302
Sep 16, 2010 03:14 PM
984x4F150
1997 - 2003 F150
Sep 5, 2009 02:44 PM
greenego
Jun 27, 2003 02:57 PM
