Sponsored by: Real Truck
front end doing some odd things
Old Feb 28, 2011 | 10:50 AM
f350girl's Avatar
f350girl
Ok, so I have an of F350 cc dually, 4x4. Bought it used, it's never had the smoothest ride but it does its job, hauling a 6 horse trailer. Last summer the front tires were wearing funny, so I had them rotated. One person told me I needed new ball joints, another said shocks... never got a straight answer so I wasn't going to dump tons of money into the truck that I dont have. The tires are wearing ok now, but the front end feels almost loose? Bear with me, I'm not that educated when it comes to this stuff. Coming home last week I was going around a left turn on the highway and the truck almost felt like I hit a patch of ice and headed to the right. No ice anywhere, pavement was dry. Scared me enough that I haven't driven it since. I want to know if you all have any ideas what it could be before I take it anywhere so they don't try to screw me over. Our local ford dealer service department is run by a jacka$$ who thinks women shouldn't have a truck and brushes me off like I'm crazy when there is something wrong with it!
Old Feb 28, 2011 | 12:15 PM
mixerdrvr's Avatar
mixerdrvr
What year is the truck?
I would take it to a competent shop and ask them about the front end, have them check it out.
Good luck and let us know what happens!
Old Feb 28, 2011 | 01:04 PM
BigPigDaddy's Avatar
BigPigDaddy
First off, welcome to FTE!
Second, the problem could very well be both the shocks and ball joints. Ball joints are a common wear item on these trucks and will affect tire wear and handling. Worn shocks will not keep the tires in contact with the roadway and, when combined with worn ball joints, can cause loss of control just like you experienced.
Third, check out the New Hampshire area thread and see if anyone in your local area can point you to a reputable repair shop (Ford or independent).
Fourth, put your truck details in your signature line so we have an idea what your truck is, it will help with diagnostics. (See my sig below for example).
Fifth, got pics of your truck?
Old Feb 28, 2011 | 02:47 PM
89LX306's Avatar
89LX306
I would start by crawling under the truck and doing a visual and hands on inspection of the front steering/suspension components. Just looking at them and trying to wiggle them could tell you a lot. I found a broken (in half) track bar on my truck this way. It darted on the highway enough to scare me and I immediately got home and crawled under it. You find that it is something obvious even if you aren't a trained mechanic.
Old Feb 28, 2011 | 06:23 PM
CornerstoneCarpenty's Avatar
CornerstoneCarpenty
Cornerstone
I had a similar problem last year. I thought that the steering box or power steering pump was bad. The truck would jerk you right across the center line of the road. It would act like it was going to fight you at the wheel and then the wheel would turn and jerk out of my hand. It ended up being the U joints on the front axle. They where frozen up, causing binding. Could be your problem.
Old Feb 28, 2011 | 07:29 PM
f350girl's Avatar
f350girl
I haven't posted enough to have a signature yet, but I have an 05 F350 CC flatbed dually, 4x4 with the 6.0L. Once I figure out how to put a pic, I will
Old Feb 28, 2011 | 07:30 PM
f350girl's Avatar
f350girl
Just read my first post... nice job on my phone using of instead of 05... sorry! I had someone else drive the truck today and it did nothing out of the ordinary until we got on the highway and it had a vibration, but did nothing else. Someone is coming to look at it tomorrow, he said something about the panhard bar. Nothing seems loose as far as tie rods, u-joints, etc but again, there was 3 inches of water in my driveway today and I wasn't exactly laying on the ground to get a good look.
Old Feb 28, 2011 | 08:46 PM
DAVE67FD's Avatar
DAVE67FD
f350girl,
Not sure what part of NH your from but if you still need help, check out Sullivan tire. Go to their web and see if they have a location near you. They are very well experienced on trucks. I use them for my alignments. They can do a diagnose on your truck if need be.
The Panhead or track bar could cause this if the bushings are worn but i wouldn't suspect it on your 05 until i exhausted all other items. How were the tires wearing before you rotated? Is the truck lifted, larger tires or stock?
Give us some more info like mileage and previous maintenance if known.
Old Feb 28, 2011 | 08:53 PM
f350girl's Avatar
f350girl
I have no idea of previous maintenance. Its got 131,000 on it. Tires were wearing with uneven low spots ..not sure how to describe it. I haven't had to do anything to it and everything is stock with 17 inch wheels. I forget the exact tire size. Hopefully after this guy looks at it tomorrow I will get a straight answer and can get it taken care of.
Old Feb 28, 2011 | 09:45 PM
bangin nails's Avatar
bangin nails
IF your in so nh see Brett at Barrett automotive in Hudson great service ,prices and no bs. Prices way cheaper than dealer ,awsome to deal with!
