Better throttle response?!?!
Old Mar 11, 2002 | 08:02 PM
fishmanndotcom's Avatar
fishmanndotcom
I own a 1993 F-150 4x4 351w E4OD. I was wondering what sorts of things I can do to greatly improve my throttle response. The truck is pretty much
stock except for I installed a K&N airfilter and I have slightly adjusted my exhaust system (cut off the muffler and piping up to the cats.) I just recently gave it a tune up. Please help. I am willing to spend alot but would prefer cheaper methods(DUH)!
-Jason-
Old Mar 11, 2002 | 08:43 PM
Lightning2Fast's Avatar
Lightning2Fast
well increasing the timing is a free mod and it definitely helps. however you should run higher octane after you make the adjustment. bump it up to 14*. youll feel it.
Old Mar 11, 2002 | 09:26 PM
Pastmaster's Avatar
Pastmaster
I can vouch for the 14 degree advance. I even got a bit better mpg with it. Another mod you might consider, it's free, is the TPS mod. I did it to my 93 5L and noticed an improvement too.
'93 F-150 loaded and modified!
Check my Gallery
Old Mar 12, 2002 | 07:46 AM
MikeS's Avatar
MikeS
>improvement too.
>Check my Gallery
What TPS "Mod" are you referring to?? Replacing it with a Mustang adjustable maybe? What should the idle voltage be set at? .95 volts??
Give us the scoop! Please!
Old Apr 8, 2002 | 07:41 PM
fishmanndotcom
I tried it and the only thing that happened was that my throttle sticks at 13-1400 RPM. Did I do something wrong?
-Jason-
Old Apr 9, 2002 | 07:42 PM
drm7's Avatar
drm7
I have the 351 and it responds pretty good. The only thing I've done is bore out the airbox and drop in a K&N. I've also put new plugs, wires, rotor, and cap about 1500 miles ago. The exhaust is si/so w/cheap Y into duals. I'm going to junk it soon as I actually think it has dropped my low-end power.
Ok, I need some help here. I have a timing gun but I can't find the timing marker. It's been a while since I've messed with timing but I thought the marker would be on/near the crankshaft pulley. Right? I have a 94 351w, can anyone tell me where the timing mark is? I have the serpentine (sp?) belt and you almost can't see the crank pulley except from just off center to the left standing at the front of the engine and looking down. So many other pulleys. I'm going to try to run 6 degrees adv on 89 octane and see how that does.
Also, which direction do I turn the distributor to advance the timing? Clockwise or counter-clockwise?
Thanks!
1994 Black/Silver F150 XLT 4x4 Reg Cab / Short Bed, 3.55 LSD, 5.8L w/84k miles, K&N drop-in
Upgrade wish list: 31x10.5, Gibson exhaust, MSD ignition, helper springs, lights
Old Apr 12, 2002 | 11:06 PM
GREASYROD's Avatar
GREASYROD
I installed a set of march power pulleys on my '92 with the 302 throttle response was the most noticable gain from that mod.
Old Apr 13, 2002 | 08:45 AM
Lightning2Fast
monkey jason
Feb 9, 2014 01:55 PM
RCrawler
136
Apr 26, 2010 01:13 PM
Sn0wMan
15
May 16, 2007 10:10 AM
rustfixer
2004 - 2008 F150
May 21, 2005 10:45 AM
eldo
3.8 & 4.2L V6
16
Aug 20, 2004 09:31 PM
