Trailer TIRE/WHEEL/AXLE alignment testing facilities
When trailer tires are mis-aligned (especially when used only periodically and under near maximum load) it can lead to catastrophic tire failure at speed.
I think we can all agree that such a thing is nothing we want to happen to a rig of our own...
Lets get some information together here. We have done it before, and I think this is important to follow up on.
Any tire, under even a normal load will wear hopefully in a gradual way - but if one or more tires/wheels/axles are skewed to the direction of travel what results is premature or even RAPID damage to the tires. Which we know are not designed the same as regular auto or truck tires, they aren't built for a great deal of torsional stress.
A mis-aligned tire in a set of four will actually rip the tread off of itself and sling it into the coachwork. At highway speeds, this can be very expensive indeed. By identifying facilities where alignment can be checked and made true - trailers can also be made much more ergonomical to pull.
We should definitely look into this.
Denny
_________________
Thanks
Dan
Hecht Trailers 800 392 6829 or Trailers, Storage, Containers, Trailer Parts, Mobile Attic, Office trailers, sales & rentals NJ, PA, NY - Hecht Trailersgohechtshop.com
They have shops in Toms River - route 9 and in Mount Holly - route 38.
When was the last time you really looked at your rolling equipment? All of the stuff that keeps your springs aligned....
Keep it coming, we need all the help we can get!
What concerns me the most is that axle stubs can become bent under certain conditions. How do you tell? Who can check it?
Many trailer axles are a forged steel or iron I-Beam, with an axle stub welded onto the end of it, or a forging with a machined stub axle.
These are connected to the leaf springs with U-Bolts, and the stub axle can be bent if impacted badly.
In practice, a damaged one is replace entirely with a straight one. They are similar in many ways to "DROPPED AXLES" used on early forties cars and trucks on the front end.
