General Automotive Discussion
minimum trailer tire ply
Old Jun 23, 2004 | 05:42 PM
snakebit's Avatar
snakebit
Question minimum trailer tire ply
I have a 1983 23' double axle travel trailer.
I use it twice a year...tops.
It is in desperate need of some new tires. 215/75/15's
It probably weighs 5000lbs (guessing here).
What load range/ply tire can I run safely/cheaply?
Thanks.
Old Jun 23, 2004 | 07:49 PM
Bordaine's Avatar
Bordaine
Get some Goodyear Marathon trailer tires 215/75-15. Only way to go
Old Jun 24, 2004 | 09:25 AM
mavinwy's Avatar
mavinwy
Actually, tire load ratings are printed on the sides of the tires. Remember to check the weight of the trailer WITH gear, water, etc.....
You say you use it twice a year.... But you do not indicate how FAR you tow it that twice a year. If you are going cross country, buy the best ones out there. If you are going 50 miles, you can probably go with a cheaper tire and simply slow down.
I use a set of peerless force 4 light truck tires on my flatbed (dual axle). Because I had them sitting around and they have a 2500lb load rating/pair... I only tow 3500 total on the trailer so it was well within the useage.
So weigh the trailer, then shop around.....
Jim
