Sponsored by: Real Truck
KPH
Old Nov 3, 2014 | 11:57 AM
KPH's Avatar
KPH
Trailering
KPH
Can I use Shell Rotella ELC extended life coolant in my 2000 f350 , 7.3 Diesel engine? If not what do u recommend ? I have 4 gallons left over from a coolant change I'd did on my international truck which has basically the same engine in it.
Thanks
Kevin
Old Nov 3, 2014 | 03:18 PM
r2millers's Avatar
r2millers
Absolutely. Good choice too.
Old Nov 3, 2014 | 04:58 PM
KPH's Avatar
KPH
Trailering
Ok, as far as flushing old coolant out...is it ok to just use radiator drain valve and flush a couple of times with distilled water. Do I need to find an engine block drain as well or is above method sufficient? (Old fluid doesn't look to bad) just doing this because it's been five or six years! Thanks
Old Nov 3, 2014 | 10:59 PM
r2millers's Avatar
r2millers
If no prior issues and coolant still appears in good shape, I would consider flushing several times but remove the lower hose instead of just the rad plug. If it was a 6.0, little different story, pulling the engine blck drain would be a must for me with the oil cooler system sensitivity.
Not a bad idea to add an oil filter too.
Old Nov 4, 2014 | 12:26 AM
scotttahoe's Avatar
scotttahoe
I pulled the block drain plugs when I flushed mine. Not a bad idea to do it plus it's pretty easy to get to and put some teflon tape on the bolts before replacing bolts to help prevent leaks.
Old Nov 4, 2014 | 06:36 AM
KPH's Avatar
KPH
Trailering
Ok, where is block drain plug located on 2000 7.3 Diesel?
Old Nov 4, 2014 | 06:38 AM
KPH's Avatar
KPH
Trailering
Or should I have said bolt(s)?
Old Nov 5, 2014 | 11:20 AM
scotttahoe's Avatar
scotttahoe
Here is some real good reading for you. This is the exact way you should do a coolant flush. Good luck and report back.
Block plug is what they are called but all the same.
https://www.ford-trucks.com/forums/9...formation.html
SoCalAngler
Oct 18, 2016 10:23 AM
LB_
6.7L Power Stroke Diesel
Dec 16, 2015 07:39 AM
jagerbomber
Apr 17, 2012 09:13 PM
GeneLaw1
Jan 20, 2012 04:06 PM
Hiflyer746
15
Sep 3, 2009 12:29 AM
