Power Brake Conversion
Old Nov 2, 2014 | 07:57 PM
Tiggie's Avatar
Tiggie
I want to convert to power brakes on my '64 F250. I want to keep the stock drums and single master cylinder if possible.
I have located a '65-66 stock power brake setup. Can I use it? If not, how about something off a larger truck or different year?
I'd rather not convert to a dual master cylinder unless there are no other options.
My entire system is fresh but I'm still standing on the pedal like my dad has for years on this same truck. Panic stops are possible but you better have giant muscles. I was hoping all new brakes would help but it didn't.
Old Nov 3, 2014 | 07:11 AM
Shadowrider123's Avatar
Shadowrider123
There is no bolt on solution for a 64 from another vehicle.
Old Nov 3, 2014 | 12:28 PM
banjopicker66's Avatar
banjopicker66
If all you wish to do is add the brake booster, then it should be a relatively easy modification, if power boosters were not factory available in '64. Number Dummy can clarify, I am sure.
I do know that factory boosters were available in '65, and I also know that later boosters up to '79 (possibly later) can be easily adapted to '65/'66 trucks - I put a '78 booster on my '66 easily enough.
If you can get a single pot master cylinder properly mated to a booster, then the hard part would be done, I think.
The issues left would be as follows:
1. Set the pushrod length between the pedal and the booster - this will probably take up the most time, and cause the most frustration.
2. Find a vacuum source from the engine
3. Bolt the booster assembly to the firewall
4. Complete other steps normally associated with changing out a master cylinder.
This is how I see your project unfolding, and wish you the best of luck.
John
Old Nov 3, 2014 | 04:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No power brake booster listed for 1964 F100/250.
Old Nov 3, 2014 | 07:33 PM
Tiggie's Avatar
Tiggie
Before we go any farther, do you all think this will help the problem? I've got good brakes but you have to stand on them. Very different from my dad's '66 F100 and my '68 Mustang, both manual drum equipped.
I wouldn't mind a newer booster if I knew it would work with the older truck. I am concerned the relationship between the pedal rod, booster depth, and master cylinder combo would be mismatched and complicated my efforts to get better brakes.
It's looks like 350's had it as an factory option? So if I can find a '61-'66 350 with power brakes, I may be in luck for a factory engineered setup?
So the chances of finding one is rare I'm guessing... How about bigger trucks and buses? There is a local yard made up of mostly 1960-1972 Ford trucks, so I do have a good selection of the smaller and larger trucks and buses.
Old Nov 3, 2014 | 07:52 PM
banjopicker66
Standing on the brakes sounds like there is still something not quite right; there is insufficient hydraulic pressure getting to the shoes.
Consider the following:
1. Have you replaced all three rubber flexible brake hoses? The two up front and the one in the rear? Over time, they swell up internally and narrow the inside passage. This isn't discernible from the outside, but it swells enough to cause problems. Normally, the swelling usually prevents the fluid from returning back to the master cylinder, which locks up the brakes, so the symptoms are not quite adding up. But if they are more than 10 years old, I would change them out anyway. By the way, this is where I would look first.
2. Have you tried double pumping? If double pumping the brake pedal improves the braking, then I would look at the master cylinder being the problem. Or air still in the system.
3. I know you stated that the entire system is "fresh." I assume the following are done?
Drums turned or replaced
New brake shoes, and adjusted as close as possible to the drums (without dragging the drum)
New or properly rebuilt master cylinder that has been bench bled before installing in the truck
New wheel cylinders
Hope this helps.
John
Old Nov 3, 2014 | 09:15 PM
Shadowrider123
On my 64 F100 the way the MC bolts to the firewall makes it impossible to use a later MC/Booster without doing some surgery.
It doesn't look difficult, but there will be some fabrication and guesswork involved.
I bought this one last year for $150 for my 65 Mustang. I went with power discs instead so Im going to use it on my F100. It looks like I can flip the mounting brackets upside down, drill one new hole and it will fit like a glove. My entire brake system is new and Im not going to swap them out for discs until they need to be replaced.
http://www.ebay.com/itm/1964-66-Ford-Mustang-Power-Brake-Unit-7-Dual-Diaphragm-Booster-Kit-Auto-Trans-/161431002430?pt=Motors_Car_Truck_Parts_Accessories&hash=item2596099d3e&vxp=mtr
Old Nov 4, 2014 | 07:44 AM
Tiggie's Avatar
Tiggie
Everything is new but the hard lines and the drums, which were lightly turned.
The only part I didn't buy new was the master cylinder, which was unused but an old stock item. It is an old reman... I didn't rebuild it. Maybe it's suspect?
Old Nov 4, 2014 | 08:09 AM
KO1960's Avatar
KO1960
For safety sake, I would go with a dual master cylinder. I have power drums, and they work well for the driving that I do. If the brake fluid is old, that can cause problems as well. Good luck.
Old Nov 4, 2014 | 08:11 AM
candoo's Avatar
candoo
I just converted my 66 F350 to New Booster and dual master. Dont go down the road of the stock 66 F350 booster. Expensive and from what I have learned only was around for 65 and 66. I had a brake shop supply me with a delco unit and dual master. With some mods it fit perfectly using the stock fire wall bracket and petal.
Booster had a threaded rod which via coupling allowed me to set the lenght of the supplied rod to the petal.
Jnissen04
Aug 23, 2014 05:59 PM
daviselliott13
Feb 13, 2010 09:18 AM
wk65
Apr 5, 2006 07:14 AM
rboeding
Feb 1, 2006 02:29 PM
lsrjf
Oct 30, 2002 02:42 PM
