Master Cylinder question
Old Aug 22, 2014 | 04:33 PM
Jnissen04's Avatar
Jnissen04
Im doing the front disk brake conversion on my truck. I found a 78 f100 at the junk yard, only thing is it did not have a power booster. I want to put a power booster in, but want to make sure i use the proper master cylinder. Will the old master work if I buy a booster, or do I need to replace the cylinder?
Old Aug 22, 2014 | 05:28 PM
JEFFFAFA's Avatar
JEFFFAFA
Ford used different M/C between power and non-power disc brake systems. I don't know if it's bore size only or rod depth in the back of it and/or mounting ears different also. Orich knows I believe. Seems like somebody else recently got a non-power M/C mounted to a bosster but had some kind of trouble. I don't remember what. I'd get a power one and be done with it if it were me.
Old Aug 22, 2014 | 08:02 PM
orich's Avatar
orich
The boosters come in different sizes like in 73 & up used like a 10+" ones, where as the 67-72 was up to about 8-" ones.
Using the 73-79 you'll have to used the 73-79 pedals setup as the booster has a different throw and sets the booster linkage won't bolt up the early brake pedal.
A non power brake MC will not work with PB Booster.
What size is your booster ? or what yr. a of vehicle did it come off of?
orich
Old Aug 23, 2014 | 11:04 AM
Jnissen04's Avatar
Jnissen04
orich
It came off a 78 f100, i grabbed the link from the MC to the pedal, but did not take the pedal. As for the booster, it did not have one, so my guess would be a 10".
Old Aug 23, 2014 | 02:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F100/350: There are TWENTY TWO different brake pedals, NINETEEN different master cylinders, SEVENTEEN different power brake boosters and SEVEN different clutch pedals, I kid you not!
Whatever master cylinder and booster you use, MUST match the brake (and clutch) pedals.
1968/72 F100/350: There is only ONE brake and clutch pedal. 1967 F100/350's use different parts than 1968/72.
Old Aug 23, 2014 | 03:09 PM
351Cleveland C4's Avatar
351Cleveland C4
Talk about complicated.
Old Aug 23, 2014 | 03:23 PM
Jnissen04's Avatar
Jnissen04
Thanks ND, looks like I'm taking another run to the junkyard. Im going start another thread for this project, and I'll take lot of pics, cause I'm positive I'll have lots of questions later as well.
Old Aug 23, 2014 | 05:59 PM
BobbyFord's Avatar
BobbyFord
Or you can go aftermarket for booster & master and fab your own linkage.
I doesn't have to be complicated
I'm going to put '77 spindles and discs on my '72 and I'll use an aftermarket 8" dual diaphragm booster, a factory '77 master cylinder and an aftermarket disc/drum proportioning valve.
I need to use a small diameter booster to clear the tall Blue Thunder valve covers.
Tiggie
Nov 4, 2014 08:11 AM
RANGER589
Sep 20, 2010 08:51 AM
66MercMan
Nov 13, 2003 05:09 PM
red and white truck
Mar 18, 2003 09:07 AM
lsrjf
Oct 30, 2002 02:42 PM
