292 Intake Milling Limits
Old Nov 2, 2014 | 07:02 PM
mcmurb's Avatar
mcmurb
Happy Sunday,
My 292 just had valves redone and was resurfaced. Heads are ECZ-G. Put new Mummert Gaskets on Heads, went to reattach intake and no fit. Suspect i need to mill the intake to fit. Measured the deck tabs on the heads and got .93, .94, .94, and .96 readings off the 1" tabs.
Question, how much do i mill off the intake to accomodate the surface loss on the heads with those readings? What is the limit i can mill off the intake (ecz-9425-B), before the flanges get too thin? If i'm out of material on this intake, what are any other intake options for the 292? Engine is in a 56 f100 used for weekend 45 mph runs to home dept so high performance is not needed.
Thanks in advance for any advice.
Bart
Old Nov 2, 2014 | 07:10 PM
f5fordgirl's Avatar
f5fordgirl
How much was milled off the heads?
Old Nov 2, 2014 | 08:37 PM
mcmurb's Avatar
mcmurb
at the max its .07" off.
Old Nov 4, 2014 | 03:46 PM
charliemccraney's Avatar
charliemccraney
It's 1.4 x the amount removed from the heads, and block, while taking into account any difference in the thickness of the head gasket.
Old Nov 8, 2014 | 09:55 AM
mcmurb's Avatar
mcmurb
Charlie, sorry i was off the grid for so long. Thanks much for the info. That seems about right to me too. off to the machine shop. thanks again, Bart
66_in_ky
Jun 25, 2012 06:40 AM
wvbogger
Jun 12, 2007 10:53 AM
leftystar
Apr 23, 2007 09:31 PM
72 f250cs
Nov 19, 2005 03:58 AM
oldmaninva
Feb 14, 2005 04:44 PM
