intake port mismatch
Old Nov 19, 2005 | 01:14 AM
72 f250cs's Avatar
72 f250cs
will a 64 4V intake fit ok on C8AE-H heads i read that 67 and up most truck heads had shorter intake ports I have a set of C6AE-R heads which i would switch if it makes a noticable differance
Old Nov 19, 2005 | 02:48 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
The year change on the heads was in 66...Prior, the intake ports are larger....there wasnt a length difference, just a diameter difference,the C6AE-R should be a large port also which should match the Intake to a T..and the C6 head will flow better than the C8's anyway... JMO...
Russ
Old Nov 19, 2005 | 03:47 AM
72 f250cs's Avatar
72 f250cs
thanks alot man i am learnig good stuff here everyday
Old Nov 19, 2005 | 03:58 AM
RapidRuss's Avatar
RapidRuss
No Problem, the guys in here are a world of FE information..and if you have a question they cant amswer? they know where to go to get the right answer!!
Welcome aboard..and enjoy your build!!
Russ
heyjoe
Jan 17, 2016 07:05 AM
jaywischmann
16
May 17, 2013 06:27 PM
hdpusher
19
Jan 8, 2011 06:12 PM
bigblue
Sep 11, 2000 07:53 AM
