75 and 78 Dana 44 F100 knuckle and tie rod boots
11-01-2014, 01:15 PM
Is there a dif in the tie rod taper between the 2 years? also where can I source new tie rod end boots? rubber will suffice.
11-01-2014, 01:39 PM
Quote:
Originally Posted by
bigcrunch
There is no difference in taper
but the 78's steering arm has more meat and the hole is bigger because the tie rod shank is beefier.
Energy Suspension has tie rod boots.. they're so lo-buck that there is no reason not to go with polyurethane.
gmill09
10-05-2013 02:01 PM
rmcgraw351
08-25-2013 10:55 PM
piney1
12-22-2009 07:50 PM
Kongslibakken
06-16-2005 10:15 PM
83 F350
1966 - 1977 Early Broncos
06-11-2003 01:23 AM
