Ford head video,,,, FINALLY!!!!
Old Oct 30, 2014 | 11:37 PM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
This one had enough meat to trim. And it was not worthy for us to bolt on.
We were expecting to do a thou final cut pass,, it didn't work out that way.
Old Oct 31, 2014 | 09:26 AM
tonefordays's Avatar
tonefordays
I only watched about half the video, however I would guess that the heat treating of the valve seats caused the head to warp. It's evident that the heat treating happened after the head was originally machined due to the visible heat affected zone. This would make sense since the cutter was only cutting on the outer edges of the of the head, the heat treating caused the metal to shrink when it cooled resulting in the outer perimeter to draw up and creating a dish.
Old Oct 31, 2014 | 09:48 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Sounds reasonable. Ford should know better. Sad they would take your money and ship it like that. Getting that info back to the proper person at Ford may help the next guy (maybe).
Old Oct 31, 2014 | 05:29 PM
04badford's Avatar
04badford
Wow Anthony , it goes to show ya Quantity and not Quality. Thanks for the Vid
Old Nov 1, 2014 | 04:41 AM
Will Bite's Avatar
Will Bite
Good techs like you are hard to find. If that was done at a dealership I would bet that they would just toss them on the truck and be done. Then when you come back in 6 months with a blown head gasket they would be quick to blame a tune or something else. With the customer not even knowing that the heads where faulty to start with.
Old Nov 1, 2014 | 06:32 AM
jmtbiggin's Avatar
jmtbiggin
Can OEM headgaskets seal with that kind irregularity. 2/1000 seems incredibly small.
Old Nov 1, 2014 | 08:11 AM
Super Duty Service
Former Vendor
Yes the warp was within "spec". But are you gonna line up and feel good about a thousand bucks for the part and have confidence when you lean on the skinny pedal??? Not me. I have a phrase,,, it's a lil cocky,, But "perfect is the benchmark". Btw that head was inconsistent with the last head I got from Ford. Both of them are video documented. The last one had a good surface but was .014 below the 3.74 spec. Ford says the heads are not mill able, but I walked out of the dealership with a head that was 3.726. So I opted to not shave that one.
Old Nov 1, 2014 | 08:30 AM
Per4mance's Avatar
Per4mance
Just asking, have you come accross any of the Chinese heads? I've heard mixed reveiws.Not that I would use them there are still plenty of real heads around
Old Nov 2, 2014 | 12:36 AM
Bently_Coop's Avatar
Bently_Coop
Great video, thanks for sharing.
Interesting how OEM parts are supposed to the best yet showing the head which costs so much could have been much cleaner.
Old Nov 2, 2014 | 03:39 AM
Maxium4x4's Avatar
Maxium4x4
You just change the specs to match the crap that IH sent out and call it good That is why the Ford techs hands were tied when repairing a vehicle, even OEM parts were trash.
Old Nov 2, 2014 | 06:16 AM
dannyboy950's Avatar
dannyboy950
Sadly this is so often true these days.
Old Nov 2, 2014 | 07:36 AM
Per4mance's Avatar
Per4mance
Quality should be job one, that's why we need more shops like Super Duty Service so the 6.0 name doesn't get tarnished anymore than it is.
Beanscoot
4 Cylinder Engines
Nov 6, 2008 01:02 AM
Snowking
25
Mar 31, 2008 09:44 PM
troposcatter
Oct 28, 2007 09:12 PM
biggreentank
Oct 19, 2006 07:54 AM
Labrador
2004 - 2008 F150
Mar 24, 2004 05:57 AM
