Fuse Blowin
Old Oct 30, 2014 | 05:49 PM
Deck Guy's Avatar
Deck Guy
Fuse Blowin
Got a 95 F350 CC 4x4, blowin the 20amp, unplugged fuel htr, drove halfway to work blew again, changed harness back to old fuel bowl harness and still blows? BTW it does have a 6 pos chip. Any help would be grateful.
Old Oct 30, 2014 | 07:15 PM
stainlessstroker95's Avatar
stainlessstroker95
You are talking bout the big maxi fuse in the box under the hood right? I thought it was a 30 amp for that fuel heater and pcm.
Old Oct 30, 2014 | 10:36 PM
madpogue's Avatar
madpogue
Which fuse?
Old Nov 1, 2014 | 12:08 PM
Deck Guy's Avatar
Deck Guy
My bad its the 20amp no. 9 under the hood, powertrain control?
Old Nov 1, 2014 | 08:23 PM
ReBilld's Avatar
ReBilld
That's the PCM fuse. Disconnect the two small wires from the GPR (glow plug relay), and jump the two big posts on the GPR to activate the glow plugs. If this helps, then the GPR is bad.
Old Nov 2, 2014 | 04:41 AM
Deck Guy's Avatar
Deck Guy
I will give it a try, disconnected the EBPS and she fired, now the trick is will she keep runnin or leave me at the mercy of AAA.... Again! Haha. Did find a wire on an old Trans command that was touchin the exhaust, it was worn so covered it and relocated it?
Thanks for your input, got 2 of these things and they never have the same issues???
pullinair
17
May 6, 2026 02:50 AM
ralleyclimber
Apr 28, 2014 11:30 AM
StillNotKing
Feb 20, 2011 07:43 PM
greagin
Jan 10, 2008 07:03 PM
bballcrf
Oct 3, 2006 01:48 PM
