351 flywheel
Old Jul 16, 2003 | 07:08 PM
Brian460's Avatar
Brian460
351 flywheel
I am in the process of swapping out a 302HO for a 351W, I know my current flywheel is a 50oz balance and I need a 28oz for the 351W.
I am going to uses a new aftermarket one I just need to know which one to get as far as the ring teeth count 157 or 164 and will my starter off of the 302 work?
Old Jul 16, 2003 | 10:08 PM
ecarter50's Avatar
ecarter50
351 flywheel
If you have the 302 out count the teeth. The new one should be the same except the balance. Yes the 302 starter will work.
Old Jul 16, 2003 | 10:34 PM
Brian460's Avatar
Brian460
351 flywheel
What I mainly wanted to know was could I use either tooth count as long as I bought the correct starter or is there clearance issues.
Poorboy1967
Sep 7, 2016 04:53 PM
eBronc3
1966 - 1977 Early Broncos
Nov 5, 2015 05:38 PM
fordtrck302
May 22, 2006 10:04 PM
XLR8DJ
Aug 23, 2005 12:32 PM
motorhead_83
Engine Swaps
Mar 26, 2004 09:53 AM
