oil pan replacement
Old Jul 15, 2003 | 02:39 AM
1989F250's Avatar
1989F250
oil pan replacement
I'm going to have to replace the oil pan on an 89F250, 351 (Windsor, I guess? - it's the original engine). I realize that I'll have to lift the engine for clearance, just wondering if any of you have gone through this proceedure and have any words of advice....any help would be appreciated. Also, how much should I be spending for a replacement pan, and where is the best source?
Old Jul 15, 2003 | 03:01 AM
Torque1st's Avatar
Torque1st
Posting Legend
oil pan replacement
Moved from the Cleveland forum.
Old Jul 16, 2003 | 10:28 AM
mdh627's Avatar
mdh627
oil pan replacement
if that is 4x4 you might have to pull the motor depending upon if it has a deep sump oil pan. sometimes on 4 wheel drive the 351w has a six qt oil pan and it will not clear the oil pump pickup tube. if it were me I would call around the junkyards. you might find one already pulled off and pick it up for around 20-25 dollars. if your wanting a new one check out jc whitney they have chrome oil pans for 50.00. you can order it online from J.C. whitney and have it 7 to 10 days or you can even get overnite shipment
Old Jul 17, 2003 | 09:11 AM
drbonestou's Avatar
drbonestou
oil pan replacement
I just pulled the pan from my 92 351w bronco 4x4..
You will have to jack engine up..make sure you block it..because you will have to stick you hand in pan ..once it is unbolted..and remove the oil pump and pickup tube to get the pan out...once pump and tube are unbolted..my pan slid right out...and it is a 6qt plus filter..also you might have to remove your down pipes from manifolds..if the drivers side crosses under the pan..
I cheated..I cut mine ..then welded a new piece of pipe in
Didnt want to break the manifold bolts
peka
Aug 26, 2015 01:51 PM
Fatfenderford
Apr 1, 2015 09:04 PM
motocrossross
Nov 4, 2014 08:39 AM
Gear619
May 3, 2014 02:07 PM
ian_ak
Alaska Chapter
Nov 30, 2013 05:12 PM
