Ignition
Old Oct 29, 2014 | 05:13 PM
1997fordf350's Avatar
1997fordf350
Ignition
Hi. When I push the lever down on the steering column going into the ignition nothing happens except for the heater working and battery gauge working. I've replaced the switch. It doesn't make a sound to turn over either. Or does it try to. It's on a 1985 ford 4.9
Old Oct 29, 2014 | 06:26 PM
ctubutis's Avatar
ctubutis
Neutral Safety Switch? Your model is new enough you may need to fully depress the clutch for the starter to operate (auto tranny in Park or Neutral).
Old Oct 29, 2014 | 08:44 PM
Franklin2's Avatar
Franklin2
Do you have a tilt column? If so, you might have the famous broken piece inside the column. It's number 14 in the picture below.
Old Oct 30, 2014 | 04:02 PM
1997fordf350
For now I've just been pushing down on the lever. And it seems good.
Old Oct 30, 2014 | 09:19 PM
ctubutis's Avatar
ctubutis
What lever are you trying to describe?
Old Oct 30, 2014 | 11:31 PM
graydad4kids's Avatar
graydad4kids
after replacing the turn signal switch I noticed the bushing between the upper bearing and the steering wheel is gone. Its part # 13B301 and I cant find one does any one know the dimensions of this bearing to replace it . Its actual name is turn signal control bushing retainer. This is on a 1986 f250
Old Oct 31, 2014 | 09:52 PM
KsCop's Avatar
KsCop
KsCop's Avatar
KsCop
Getting back to the original post - 1985 F150 4.9
WHAT LEVER?
Old Oct 31, 2014 | 09:55 PM
1997fordf350
The rod that pushes the ignition switch
Old Nov 1, 2014 | 08:00 AM
ctubutis's Avatar
ctubutis
Remove the small red/blue-stripe wire from the starter solenoid and connect that wire to a voltmeter (the other voltmeter wire goes to ground). Turn the key to START (or actuate the switch by moving the rod, in your case) and you should see battery voltage at that wire; this is what actuates the starter motor solenoid.
That red/blue wire may be interrupted by a Neutral Safety Switch, which also needs to be closed for power to flow through it.
Old Nov 1, 2014 | 06:19 PM
1997fordf350
Is the positive battery cable supposed to be connected to the starter solenoid with everything else?
Old Nov 1, 2014 | 06:56 PM
ctubutis's Avatar
ctubutis
Yes.
<!-- xxx -->
Thinlizzy13
Aug 2, 2019 08:49 PM
rtcalabrojr
Dec 20, 2011 12:29 PM
johnfl
Jul 31, 2010 08:01 AM
ferguson777
Mar 24, 2008 11:17 AM
RabidJade
Electrical Systems/Wiring
Jun 29, 2006 01:14 PM
