Sponsored by: Real Truck
7 blades 5 wires
Old Oct 29, 2014 | 10:36 AM
ehusmann's Avatar
ehusmann
7 blades 5 wires
I've searched and haven't found an answer to my problem. Son-in-law has a 2010 F250 and recently purchased a car trailer. The trailer has 5 (black, red, white, green, yellow) wires going to a 7 blade plug. From experience and checking the trailer I'm confident that the green and yellow work the turn signals and the white is ground. I suspect the black is power and red is brakes and stop lights. The 250 wiring diagram shows separate wires for brakes and stop lights. Do I need to run another wire to the brakes or stop lights or can I just jump between two blades on the trailer plug to power the brakes and stop lights? Thanks
Old Oct 29, 2014 | 11:01 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
If the trailer doesn't have electric actuated brakes then the brake wire isn't needed.
Old Oct 29, 2014 | 11:29 AM
r2millers's Avatar
r2millers
You need a separate wire for the electric brakes. You have to use your brake controller that allows for variable voltage to operate the brakes.
I can't imagine not having brakes on a car trailer. You might check to see if the trailer is using surge brakes instead.
Here's the 7 pin diagram for reference.
Trailer Wiring Diagrams | etrailer.com
Old Oct 29, 2014 | 12:00 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
If the trailer harness is only 5 wires then it doesn't have electric brakes.
Old Oct 29, 2014 | 12:07 PM
ehusmann's Avatar
ehusmann
The trailer does have electric brakes and the truck has a Ford installed brake controller. The trailer was previously pulled with a 2005 F150 with an aftermarket controller. I suspect the brakes and stop lights worked off the same wire connected to the "brake" spade on the 150's plug.
Old Oct 29, 2014 | 12:32 PM
r2millers's Avatar
r2millers
That's crazy. Pretty unsafe too.
Follow the wiring back and re-wire properly.
No jerry rigging here.
Old Oct 29, 2014 | 12:46 PM
Sebs's Avatar
Sebs
If the trailer doesn't have backup lights or a battery, 5 wires is all you need. They are:
1. Left turn
2. Right turn
3. Tail light
4. Brake controller wire
5. Ground
The left and right turn signal bulbs are also the brake lights. When you put on a turn signal you are simply flashing the brake light on that side.
Old Oct 29, 2014 | 03:08 PM
speakerfritz's Avatar
speakerfritz
yes....and with out the brake controller....odds are that the trailer brakes is also stopping the truck
Greg5OH
Feb 13, 2013 12:33 PM
Sycostang67
All Things Towing
Nov 30, 2008 04:27 PM
togobefastguy
All Things Towing
Jul 30, 2008 09:09 PM
Jbailey52
All Things Towing
Mar 12, 2008 07:42 PM
baddarryl
Electrical Systems/Wiring
Mar 22, 2006 05:14 AM
