Rear Differential/Axle Identification
Old Oct 29, 2014 | 09:51 AM
LvBohemian's Avatar
LvBohemian
I did not see any sticky's on this...
I am wondering what the easiest way to determine what Rear Differential/Axle I have in my 1995 F-250 XLT 2-Wheel Drive 460/7.5, is it a posi, etc?
looks like this is what might be in it...
1995
  • full-floating, 3.55 ratio
  • full-floating, 4.10 ratio
  • semi-floating, (ABS), 3.55 ratio
  • semi-floating, (ABS), 4.10 ratio
Old Oct 29, 2014 | 10:51 AM
rla2005's Avatar
rla2005
Look at the door jamb sticker on the b-pillar ( aka door jamb). There will be a code listed for the axle. FYI it's going to a full floating Sterling 10.25 with a 3.55 or 4.10.
Most likely your axle code is going to be a 35, 39, C5 or C9. 35 is a 4.10 non-LS. 39 is a 3.55 non-LS. C5 is a 4.10 Limited Slip.C9 is a 3.55 Limited Slip.
Davidvc1964
6.4L Power Stroke Diesel
May 22, 2013 10:20 AM
nstueve
Jun 30, 2009 08:29 AM
symonds86
Sep 23, 2007 08:26 PM
John B
Aug 29, 2004 02:01 PM
GregCS
Mar 1, 2000 10:27 PM
