solid dana 44 questions
Old Oct 29, 2014 | 09:35 AM
Jarryd's Avatar
Jarryd
If I want to swap in a solid axle, can I use my factory upper spring bucket with shock mount and can I use any of my other lift components from my current setup? I'd like to do this in the future but I want to make know going in what pieces I can reuse.
Old Oct 29, 2014 | 11:50 AM
GoinBoarding's Avatar
GoinBoarding
You currently have a 2wd f150 with a 4" lift, correct? I don't know the answer to your question but those that do may not have your truck specs memorized.
Old Oct 29, 2014 | 11:51 AM
Jarryd's Avatar
Jarryd
That's what it is. I didn't think it mattered too much since everything above the ttb is the same.
Old Oct 29, 2014 | 12:29 PM
Evan_P's Avatar
Evan_P
I think about the only thing you could reuse is extended brake lines and the drop pitman arm. The coils for a Dana 44 SA are different and wont mount into the current towers. This means you'll also need a new shock tower mount. Basically everything you just put on for the lift will have to come out and be replaced.
Old Oct 29, 2014 | 12:31 PM
Jarryd's Avatar
Jarryd
that's what I was afraid of. At that point I may as well just put in a 60, it would take as much work.
1972RubberDuck
16
Nov 12, 2016 01:30 PM
78Whiteboy
Bronco II
Dec 14, 2006 05:50 PM
kevinupchurch
Offroad & 4x4
Dec 17, 2004 03:04 PM
Thunderace31
Aug 3, 2004 08:58 AM
lr
Offroad & 4x4
Sep 15, 2003 03:22 PM
