I took part in the ford survey.. almost bagged it when they started the part about "which would you buy" ford, gm etc...
got to be a bit too much like a sliezy car salesman asking questions too see if you are a good "UP", not how ford can or should allow personal to post advise and tech info on the forum.
they did not provide a NR (no response) or NA (not applicable) response so i would just click the 5 box, the scale was 1-10.
I hope they see the value of what guys like Mark K have provided as retired ford engineers, in correct info about products and conditions.
just my 2 cents which when figured in GPD is worth .005cents..
