no fu el to engine
Old Oct 26, 2014 | 01:44 PM
Futzy's Avatar
Futzy
no fu el to engine
Let me start be saying I'm a car noob. I was driving in Betty my 73 f250 360 4 speed and all of a sudden she started sputtering and died. I got under the hood and pumped the throttle manually and she started up got ten feet down the road and died again. It feels like there is no fuel getting to the engine, but as I said I'm still learning. Any ideas? Please help.
Old Oct 26, 2014 | 03:25 PM
HIO Silver's Avatar
HIO Silver
Outta gas?
Fuel filter clogged?
Old Oct 26, 2014 | 06:59 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
x2 on the 1st two suggestions to ck? Or maybe the fuel pump died?
Purchase a Chilton or Hanes manual for cheap at the parts store for your truck, it will have some troubleshooting steps. And help with the truck noob-ness.
Could also be a clogged fuel sending unit, pick up tube sock filter (in the tank). But there are easier things to check 1st like fuel filter....then the fuel pump.
Old Oct 26, 2014 | 11:19 PM
Futzy's Avatar
Futzy
Thanks for the suggestions guys. The fuel pump was making a ticking noise from time to time. I'm assuming that might have been the sound of a slow death?
Old Oct 26, 2014 | 11:30 PM
77&79F250's Avatar
77&79F250
Usually they work then just die. Not hard to change a mechanical fuel pump, it is covered by the basic Chilton manual. Also replace a few inline fuel filters and but some fresh gas and see what it does.
Also ck your soft lines by the eng side fuel pump and the soft lines back by the fuel sending unit, to be dry rotted and cracked and sucking air.
Tidife
18
May 20, 2014 09:53 PM
Brad_81Ford
Jan 15, 2012 10:21 AM
clwoodall_76
Dec 4, 2009 10:11 AM
87longbed150
Mar 24, 2007 09:14 PM
mike L
Sep 1, 2004 04:23 PM
