Console top replacement
Old Oct 26, 2014 | 09:41 AM
mltdwn12's Avatar
mltdwn12
I just bought a 2005 F-150. It's in great shape, the only thing that's odd is this wooden piece on the end of the console. It certainly looks home made or aftermarket. Does anyone know where I can get a replacement part that matches the rest of the interior.
Old Oct 26, 2014 | 09:43 AM
mltdwn12's Avatar
mltdwn12
This is the current piece
Old Oct 26, 2014 | 12:01 PM
danorules's Avatar
danorules
I would recommend checking a local scrap yard
Old Oct 27, 2014 | 04:00 PM
ojai150's Avatar
ojai150
I would recommend refinishing the wood , and keeping it ,
I'm pretty sure a scrap yard is going to charge you for the entire console .
Old Oct 27, 2014 | 08:21 PM
clintonvillian's Avatar
clintonvillian
My rubber is coming loose on mine, and it is annoying. I wonder if that us why that one is wood.
Anyone know how to get it apart?
Old Nov 20, 2014 | 01:12 AM
thzpcs's Avatar
thzpcs
This should be the right part if I'm reading the diagram correctly.
Old Nov 20, 2014 | 07:58 AM
clintonvillian
Does anyone know how to remove this piece? how was the wooden one attached?
Old May 22, 2015 | 09:31 AM
clintonvillian
Pulling this back up, the rubber pad has now ripped and is floppy.
Does anyone know how to remove it without tearing it up???
Old May 22, 2015 | 08:30 PM
mds47588's Avatar
mds47588
Mine was a royal PITA. I used a buncha superglue and then put a lil bit of weight on it to keep it in place. After a few hours of drying time (a lot more than necessary) I then used a small screwdriver to slowly work the outer lip of the rubber piece around the lip on the console lid.
Voila! Done!! Two months later and it's not moved a bunch.
Can't really tell for sure in the pictures, but it seems as if someone did good work making the one in the O/P.
powellbj
Jan 8, 2017 08:00 PM
Bowie
Jan 9, 2014 05:53 PM
Krisx125
WTB - Parts & other
Mar 13, 2011 08:30 PM
evilwayz7
2004 - 2008 F150
Nov 27, 2010 11:02 PM
e william
Jan 3, 2009 09:13 AM
