96 F150 won't steer without revving engine
My 96 F150 4wd 5.0 will not turn the front wheels left or right unless I rev up the engine some. With the engine at normal idle it just won't turn. My 95 F250 4wd 5.0 turns easily at idle. They have approximately the same size tires if that matters. Any ideas? Thanks.
The pressure regulator valve unscrews from side of the pump... if you think that's the problem then go snag one from the junkyard and try it out before you buy an entire pump.
See that hex head on the side of the pump where the hydraulic line goes into it? Well if you remove the line and put a wrench on that hex then the valve (and spring) comes out without having to do anything else. The spring is pretty weak so don't worry bout how you're gonna put it back together or anything, you can do it by hand.
Many thanks
Okay, many thanks for the good info. I plan to keep this truck for a long time. Probably a race to see which one of us dies first.
There is no binding of the mechanism and the belt is not slipping, so I will just replace the pump.
Anybody know if reman pumps from local parts houses are okay, or should I go with a new?
Flat Ernie
03-29-2016 08:56 PM
Bryanblaylock
03-09-2016 06:06 PM
Jeff and Nicolle
01-24-2012 08:07 PM
Randyb12
08-04-2005 11:01 AM
