2004 Explorer Throttle Position problems and more
Old Oct 25, 2014 | 07:53 PM
gbill's Avatar
gbill
Here's the history of the 2004 Explorer with 4.0 V-6 problem:
Wedneday: engine turns over but will not start
Thursday: Code reader shows throttle position sensor 4 times, ordered one.
Wrench light and service engine lights on.
Saturday: Installed new complete throttle actuator assembly
Turns over, will not start.
Disconnect battery & reconnect, will not start.
Unplug MAP sensor, now it starts, but will not rev up.
Turn on key, push pedal to floor, slowly release, still no rev up.
Buy and install new MAP sensor but will not rev up.
Repeat pushing pedal to the floor, and releasing slowly.
Code still shows throttle position sensor. Try clearing codes and
re-reading code, still shows throttle position sensor.
Wrench and service engine lights still on.
Try calibrating throttle few more times.
End of daylight Saturday: out of ideas. Looking for more. Could it be the actual foot pedal control?
Thanks for reading, help appreciated. "Moma" wants her truck back ;-)
Thanks, Bill
Old Oct 26, 2014 | 10:39 AM
shorod's Avatar
shorod
Please include the actual code numbers that are stored.
Since unplugging the MAF seems to help, I'd suggest you check for pretty significant vacuum leaks. Are you absolutely certain that you have all the intake air tubing correctly installed from the MAF to the throttle body?
-Rod
AlsF150s
2004 - 2008 F150
Dec 28, 2017 10:07 AM
chop33
Jan 6, 2011 09:57 PM
magnet1
2004 - 2008 F150
Dec 17, 2010 02:29 AM
Sethw3
2004 - 2008 F150
Oct 13, 2008 07:07 PM
Craig64
Jun 6, 2008 06:42 PM
