Left-Hand Thread Lugnuts. Why???
Old Oct 25, 2014 | 06:06 AM
1978f-250's Avatar
1978f-250
I didn't want to hijack the other thread but I need to ask because I've never heard of left-hand thread lugnuts.
Were these stock equipment from Ford?
Why were they used or needed?
What purpose do they serve over right-hand thread lugnuts?
Dennis
Old Oct 25, 2014 | 06:15 AM
Tedster9's Avatar
Tedster9
The idea was that the forward rotation of a rolling wheel would tend to keep wheel nuts from loosening or coming off. I guess. Seems like a solution in search of a problem.
Old Oct 25, 2014 | 06:28 AM
jim collins's Avatar
jim collins
First time I heard about left hand nuts on a Ford too. I knew they were on a few cars back in the 1930s ,40s and 50s , on a lot of Chrysler products on the passenger side only. What years Ford did they come on and what series ? New one on me , i guess i'm not to old to learn something new.____JIM
Old Oct 25, 2014 | 09:52 AM
ShaneNP123's Avatar
ShaneNP123
been around for quite some time, less common now. International used them quite a bit. Still used on some heavy/military spec trucks
Old Oct 25, 2014 | 12:44 PM
jim collins
That i know but how about Ford ? That was my question , i have owned a few that way but not a Ford.
Old Oct 25, 2014 | 05:13 PM
Sooper Camper's Avatar
Sooper Camper
it was pretty standard practice back in the day on heavy duty pickup trucks. "L" stamped into the end of the stud is a dead giveaway, as well as a "notch" stamped onto the hex of the nut (most LH nuts are this way).
its pretty simple, same concept as bike pedals and crank bearings. personally, I prefer it, but if you are having someone change your tires for you, you definitely need to make them aware. most tire store guys nowadays would just hammer away at it in the wrong direction till they either strip a stud or crack your wheel.
Old Oct 26, 2014 | 08:53 PM
Tedster9's Avatar
Tedster9
Well Ok.
Was there a big rash of passenger side wheels departing from the vehicle though, back in the day?
Guessing manufacturers wouldn't have gone through the trouble of doing this - though nobody seems to bother with it anymore, either. Hm.
Old Oct 26, 2014 | 09:15 PM
dlburch's Avatar
dlburch
it was the driver's side that used left-hand threads...
:::MoparMax::: Steve Mags Speaks - The Mystery of Left-Hand Lug Nuts - 05/03/10
Old Oct 27, 2014 | 12:10 AM
Tedster9's Avatar
Tedster9
Interesting "the rest of the story", so it wasn't really necessary, and caused more problems than anything else.
Old Oct 27, 2014 | 01:35 PM
HardkaseDaddy's Avatar
HardkaseDaddy
Yeah I banged out the left hand studs on my '73 scs project and put all right hand threaded studs and lug nuts on my truck. Science and common sense has changed the general world view on mixing left and right handed wheel fasteners on one vehicle.
Old Oct 27, 2014 | 02:06 PM
Tedster9's Avatar
Tedster9
Back in the day, tires didn't last long at all, and flats were more common. So it's probably true a visit to the tire shop or garage and wheel service was more frequent and seasonal snow tire changeout, etc. maybe it made a certain kind of sense.
Old Oct 27, 2014 | 10:39 PM
g-man-75's Avatar
g-man-75
Was it only one wheel with left hand threads on these trucks? I have a '74 F350 only the rear pass side has left hand, I read somewhere on here they only had one wheel with left hand threads, instead of front and rear on the pass side. I thought someone over the years replaced a worn front rotor so mine ended up this way. Any insight?
Old Dec 15, 2025 | 02:17 PM
bullheimer's Avatar
bullheimer
It's back from the grave!
My 74 F350 is that way now but not from the factory. I needed new rotors for the front and the only one i could find were for an F250, which has lugs with right hand threads. (And smaller diameter lugs) I'm in Walmart for tires and they couldn't get the drivers side off. I forgot the sob was left hand threads.
Old Dec 15, 2025 | 04:22 PM
tbear853's Avatar
tbear853
I know Chrysler products used them on the left side up into the late '60s anyways, was before torque wrenches were in everyone's tool budget, unless building engines .... etc. I never even saw one in use until early '70s, one just tightened things good'n'tight as seemed proper. People relied on 4 ways, and learned no to stand on them. I remember even seeing NASCAR pit crews using 4 ways, skillfully (seen a few drive down pit road and throw one off too). Had a great uncle once explain how it was believed that if a nut or nuts were a hair not tigt, the forces of braking would tend to tighten, not loosen a nut.
Must have worked, as I never saw a left side run away wheel. Was Chrysler started with "Safety rims" too as I recall, the hump that keeps a tire bead seated like if low or flat..
Old Dec 15, 2025 | 06:40 PM
440 sixpack's Avatar
440 sixpack
Real trucks have used LH threads on the left side forever and they still do. I question if it really has ever prevented a lug from loosening but that's the way it is.
My '79 F350 CC has LH threads from the factory. my '70 Challenger does too but it was a 1 year thing.
