Smoking Hydra
Old Oct 24, 2014 | 06:00 PM
Traildust's Avatar
Traildust
Smoking Hydra
I installed a PHP Hydra a few days ago and am fairly happy with it so far. I do have to say it produces a lot of thick black smoke with the 80 hp performance, 100hp performance and up. The 140 extreme is extereme if you like smoke. I am thinking that the Ford AIS I have installed isn't helping and maybe it's time to go back to the 6637 Air Filter even though I do not like the noise from it. Any of you out there running a Hydra seeing a lot of smoke with the higher settings?
Bill
Old Oct 24, 2014 | 06:12 PM
snknby123's Avatar
snknby123
I have the Hydra and have run the PHP 80 and 100hp with the AIS. Only see a haze at night for the most part unless I'm really heavy on the pedal during the day but its not thick black smoke.
Is your turbo spooling up? Boost leaks maybe?
Old Oct 25, 2014 | 03:47 AM
Traildust's Avatar
Traildust
I am seeing 25# boost so don't think there is a leak. I even see black smoke wth the 65hp dd, not as thick as with the 100 or 120 but it's very noticable. I also have a Superchips Micro Tuner and the truck smokes a lot with it's two programs. I think I'll put the 6637 back on and see how it does.
Bill
Old Oct 25, 2014 | 08:48 AM
Tugly's Avatar
Tugly
25 PSI max? Your wastegate is likely opening. Red line mod will help this.
AIS intake, 4" exhaust, red line mod, stock everything else, and a tuner:
It's not the AIS... and you can't get more than about 60-65 HP out of tuning alone on stock sticks. To demand more than that makes heat and smoke. When buying big tunes, read the fine print - it should say something along the line of "you will need additional modifications to the truck to achieve these horse power gains".
Old Oct 25, 2014 | 09:44 AM
snknby123's Avatar
snknby123
Not sure if this would be a factor but are you sure you loaded the correct PCM code for your tunes?
I would get the Torque app running and monitor some parameters like ICP and IPR. Might help out with finding the issue.
Old Oct 25, 2014 | 08:37 PM
Traildust's Avatar
Traildust
Disconnected and plugged the red line. I selected ICP, MAP and Boost on the Scangage. Dialed in 120hp Racing on the Hydra. MAP show 36.2 boost 36.6 and next the actual Boost Gage only showed 23 to 25 psi. ICP would run anywhere between 2600 to 2950 on hard acceleration. Still smoking away when really standing on it. I never got an SES light, does the Hydra prevent defueling when it gets over 22 to 23 psi? I also have a Bank's Big Head Actuator with 6 1/5 turns to shorten the rod ( it was disconnected this time though). If I just go by my Isspro 0 to 30 psi gage I never saw more than 25 psi and to get that I had to stand on it to the tune of 3000 rpm or a little more. My PCM code is AEB2 as it came from the factory but had it relashed to AEB4 so that the old SCMT 1700 would work. Using Hydra Flash program I used the HEX code for the AEB2 as that's what it called for.
Bill
Old Oct 26, 2014 | 09:17 AM
Tugly's Avatar
Tugly
If it's not a custom tune for a modified truck, try this:
Old Oct 26, 2014 | 03:52 PM
Traildust's Avatar
Traildust
I don't have a modiefied valve body, I have a 6 speed does that make a difference? If not, should I just try and run the VRAA653 and clear out the TOAA4Z2 I am currently running? I still don't understand why my Isspro Boost Gage sees only 25 psi and the Scangage MAP and Boost are seeing over 36?
Thanks,
Bill
Old Oct 26, 2014 | 04:10 PM
Pikachu's Avatar
Pikachu
MAP and boost shouldn't be reading the same, unless you happen to be in outer space Boost should read MAP minus your local barometric pressure, which at your elevation would be about 12.7. I'd have to imagine the boost gauge is probably accurate, and the boost reading from the scangauge is erroneous.
Old Oct 26, 2014 | 08:51 PM
Tugly's Avatar
Tugly
Maybe this will clear up some confusion. Do you get the same message circled in red below?
MAP 36 at 12.6 PSI elevation pressure works out to just over 23 PSI boost, but random sampling doesn't tell us much. Graphing the MAP sensor (after recording) along with a bunch of other PIDs tells us what's going on with the engine. Trying to "catch" a number on the gauge by glancing over while your foot is making like Fred Flintstone may very well miss some details.
Old Oct 27, 2014 | 02:02 AM
Traildust's Avatar
Traildust
Found the problem with the map and boost reading on the scangage, the boost MTH setting was wrong. I had to play with it some but got it straightend out, now boost reads 00 with KOEO it was reading same as map at 12.4 to 12.6.
The Recommended Preferred Calibrations was there with TOAA4Z2 recommened.
Guess I will need a AE to get the reading needed.
Bill
Old Oct 27, 2014 | 05:41 AM
Tugly's Avatar
Tugly
If you have a laptop or netbook, AE is a powerful choice for the money. If you have a portable device, there are a few useful apps - but Torque is the flavor of the month. Your scan gauge is nice, but I assume it doesn't record or display graphs.
Old Oct 27, 2014 | 04:09 PM
Traildust's Avatar
Traildust
Thanks Tugly, the scangage monitors a lot of things but I am affraid thats about all it does, no record or graphing that I know of. I have been meaning to get the AE and this is one more reason. I guess I will need a new laptop first, mine is old and slow doesn't even have wifi. Looks like I may need to get real busy on the honeydo jobs to get the CFO to ok a new laptop and the AE.
Bill
JAMSRF250
Aug 13, 2015 08:46 PM
davalt75
6.4L Power Stroke Diesel
Sep 19, 2014 07:33 AM
Djones2121
Jan 17, 2013 06:05 AM
LaxPlaya21
Sep 13, 2010 09:35 PM
Ford Truck Racer
48
Mar 25, 2006 12:03 AM
