Sponsored by: Auxito
truck problem
Old Oct 24, 2014 | 01:37 AM
millerm740's Avatar
millerm740
Exclamation truck problem
So my 98 f150 xlt 4.6 is having a issue where the truck is jumping from 1500 rpm to about 2500 - 2600 rpm. You know sitting there trying to get up to speed. then all the sudden i look down and its at 1500 rpm. but still not really going anywhere. So i give it a little more throttle or gas and it jumps from 1500 to about 2500. Its been like this for a month but i thought it was crap fuel. Any ideas on the caused or maybe a solution? help appreciated.
Old Oct 24, 2014 | 08:46 AM
steve(ill)'s Avatar
steve(ill)
are you setting in the driveway idle or are you running down the highway ? Does the transmission down shift ? What is happening when the motor revs up ?
Old Oct 24, 2014 | 04:33 PM
millerm740's Avatar
millerm740
I'm going down the road . When it down shifts it will very slowly lower the rpm. This problem is usually when I'm going about 45 - 55 or when going up a high incline.
Old Oct 24, 2014 | 04:48 PM
enriched&beyound's Avatar
enriched&beyound
Is the tranny at correct fluid level?
Old Oct 24, 2014 | 05:39 PM
millerm740's Avatar
millerm740
Yes sir im thinking i need to change the fluid plan on doing it Tuesday i bought it used and the transmission fluid needs change.
BroKen57
6.4L Power Stroke Diesel
Nov 24, 2018 02:13 PM
Bowhunter335
2009 - 2014 F150
Jun 14, 2017 06:51 PM
mechelement
64
Feb 19, 2010 06:08 PM
lead623
Nov 28, 2006 12:39 PM
xrayman
Sep 3, 2004 04:40 PM
