Water Pump Replacement - Question
Old Oct 27, 2014 | 06:58 PM
Spool&Go's Avatar
Spool&Go
Bought the heavy duty serpentine belt. Also I think the pulley nearest the dipstick that you can see in the following link has a squeak or grind in it.
http://www.evernote.com/l/APNPTRx_6k...Yh_H_-fgV7duc/
I picked up a pulley but the kid at Napa sent me to the warehouse to get it and it wasn't the right one.
Anybody replaced this before?
Old Oct 27, 2014 | 08:15 PM
ScaldedDog's Avatar
ScaldedDog
Your photo is of the AC compressor. Is that what's squealing, or is it the tensioner right beneath it? The tensioners do fail, and can squeal. Search this forum for pics of bad ones, and compare them to yours.
Mark
Old Oct 27, 2014 | 09:14 PM
Spool&Go's Avatar
Spool&Go
It sounds like the AC compressor wheel has a minor grinding noise but its hard to pinpoint.
The squealing could be coming from that or the belt. I could have 2 noises going on. I'll get a friend to hit the throttle so I can listen better for where the sound is coming from.
Hopefully the new belt is all I need.
Old Oct 27, 2014 | 09:34 PM
Skip1970's Avatar
Skip1970
what kind of milling is done to that coolant filter water pump? id like to get one from international for cheaper and do the milling myself to get that spin on filter setup.
Old Oct 29, 2014 | 02:41 AM
Spool&Go's Avatar
Spool&Go
Just as a follow up. I replaced the serpentine belt with the new heavy duty one after lubing up all of the pulley bearings & wiping the faces on them really well.
Drove it around the neighborhood and no more squeal.
Everything is quiet now. Confirmed that the water pump went in perfectly.
Thanks all.
GeneLaw1
Oct 15, 2022 10:37 AM
ranagent
Mar 2, 2015 12:12 PM
JamesHajek
51
Apr 15, 2012 09:08 PM
EBSTEVE
Jul 28, 2005 09:54 AM
firebug
Aug 25, 2004 04:07 PM
