Need help identifying this axle
Old Oct 23, 2014 | 05:35 PM
JoeFin's Avatar
JoeFin
Would like to get this right the first time.
If I'm going to keep this Tow Truck I'll need a taller set of gears in the rear axle. 55 mph Max is just not enough for me and if one of my boys happens to drive it they'll surely bring it back with a sucked valve.
This is from the door plate
F37YRP41683
W.O. 135
Color M
Model F374
Body 4B8
Trans A
Axle 28
Max Towing 10,000
Net HP 156
RPM 4000
DSO 72
It is completely original at this point so I tend to believe the valve cover engine information which is telling me I have a 360 cu.in. FE block
If anyone can steer me in the proper direction as to what gear set to order for the rear axle to increase the drivability of this beast I sure would appreciate it.
And no I don't plan on doing any towing with it as I have a 2014 Ram 2500 4x4 with the Cummins in it. Would be nice as a project for a nostalgic weekend driver and that is where my thoughts are leading with it
ON EDIT
Sorry guys - I should have used Google first. I see it is a Dana 70 with 4:56 gear set. Question still stands what should I do for a taller set of gears
Old Oct 23, 2014 | 05:45 PM
51M1's Avatar
51M1
F37YRP41683
W.O. 135
Color M
Model F374
Body 4B8
Trans A
Axle 28
Max Towing 10,000
Net HP 156
RPM 4000
DSO 72
If you look on the rear end center section, there should be an identification tag that can be decoded to find your rear end gear ratio etc.
Old Oct 23, 2014 | 05:48 PM
JEFFFAFA's Avatar
JEFFFAFA
28= 4.56 RATIO Dana 70.
Old Oct 23, 2014 | 06:20 PM
HIO Silver's Avatar
HIO Silver
Gear options abound. I'd opt for a 3.54.
RING AND PINIONS
Old Oct 24, 2014 | 02:34 AM
351Cleveland C4's Avatar
351Cleveland C4
Originally Posted by HIO Silver
I'd opt for a 3.54.
As would I
Old Oct 24, 2014 | 11:49 AM
Gettysburg150's Avatar
Gettysburg150
edit, answered my own question
Old Oct 24, 2014 | 04:36 PM
JoeFin's Avatar
JoeFin
RING AND PINIONS
Thanks for the recommendation and the link. I'll be ordering the 3:54 set.
Old Oct 24, 2014 | 06:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
In order to install 3.54 gears in your F350's Dana 70, you will also need to change the differential case.
Dana 70 wasn't available with 3.54 gears until 1983. 1961/82: 3.73 - 4.10 - 4.56 - 4.88 - 5.13
Dana 70 rear axle ID tag located under 2 of the bolts that retains the inspection cover to the housing, but...
Today, many of these tags are missing.
Old Oct 24, 2014 | 07:11 PM
351Cleveland C4
In that case you may be better off with 3.73s.
Old Oct 24, 2014 | 07:19 PM
NumberDummy
Same problemo with 3.73 & 4.10 gears, the case is different than with 4.56 - 4.88 - 5.13 gears.
Old Oct 24, 2014 | 07:54 PM
351Cleveland C4
In that case, things just got more complicated anyway. Get 3.54s and the right case.
Old Oct 25, 2014 | 03:49 PM
JoeFin's Avatar
JoeFin
Thanks for the information Bill - you saved me quite a bit of frustration
It also appears that the 4:56 was not the smallest ratio for that rear end either
On Edit -
Yes I downloaded the manual from Dana's website and it shows 5 different versions of the Dana 70 axle with 3 different amounts of offset between axis of the ring and pinion
Old Oct 25, 2014 | 04:57 PM
JoeFin's Avatar
JoeFin
Here is the information off the axle
On the right side - the date of manufacture is ( 5 16 202)
next to that according to Dana's parts manual is the part # 603201 14
along the left side where the ratio tag should be we found
02TA - HCA
603201-14
4.56
Old Oct 25, 2014 | 05:06 PM
NumberDummy
D2TA - HCA / 603201-14 / 4.56
Ford: D2TA-HCA ~ Dana: 603201-14 .. Dana 70 Rear Axle / 4.56-1 / No Limited Slip / 7,400 lbs. Rear Axle Capacity.
96ford250
Jul 16, 2014 07:57 PM
Buzz44
Jun 22, 2012 12:13 PM
diesel_dan
Jun 12, 2008 09:26 PM
nsaikia
Oct 11, 2005 07:48 PM
Monte Doenz
Oct 4, 2004 08:55 PM
