Sponsored by: Auxito
2002 f150
Old Oct 22, 2014 | 05:09 PM
jessethorn13's Avatar
jessethorn13
2002 f150
Yes I have a 2002 f150 4.6L triton. I've been having problems with it making a clicking noise. It only does it when its in gear.I put it in park or natural I hear nothing. But as Soon as I put it in drive or reverse and put a little pressure on throttle it starts to tick pretty loudly. Its got me scrathchin my head please help
Old Oct 22, 2014 | 08:34 PM
pdqford's Avatar
pdqford
Leaking exhaust manifold/s ?
Old Oct 23, 2014 | 04:39 AM
jessethorn13
I have already had those installed when I replaced my exhaust with flow masters.if I have someone get in truck and put it in gear the noise to seems come from the tranny
Old Oct 23, 2014 | 06:00 AM
enriched&beyound's Avatar
enriched&beyound
Is the tranny filled to the correct level of fluid?
double check those U-joints and re grease the drive shaft yoke where it goes into the tranny
Old Oct 26, 2014 | 11:00 PM
mark_5102's Avatar
mark_5102
i had a similar problem this fall with my 98. it was parked for some time, and when i started driving it it made a ticking noise under torque only. i took it to a freind, we hooked a scan tool and couldnt find anything. we finally found it when i was slowwwwly climbing a hill. i kept it in gear but the incline was enough to keep the truck in place. the noise was coming from the torque converter. shortly after i found it it went away, but we are pretty sure it was a weight on the outside of the tc that was falling off, or it wasnt on properly and either spun back inline with rotation or fell off. not sure if it it your issue, but id open the rubber cover and see if you see anything in there that looks out of place.
jrod117
1997 - 2003 F150
Dec 10, 2010 07:26 PM
Homelessduck
33
Nov 20, 2006 10:06 PM
farrsfastfords
Feb 25, 2004 01:53 PM
redtantrix
Dec 11, 2003 11:25 PM
Redneck 83
May 1, 2002 06:05 PM
