Sooo frustrated... 6 months without my truck
#31
Well mine is new, so I had no sludge to remove! And I was worried about wiping the crank bearings, but I never used it for anything other than driving up and down the road staring at gauges... and with 70 cranking pounds, I should be good. One thing in our favor is a tough bottom end on these engines.
Maybe we'll both get our trucks running in the next couple of days... if we didn't live 3.4 light years away we could have some beers to celebrate.![Drink to That](images/smilies2/party0005.gif)
#34
#35
#36
Haven't tested sides yet. I hurt my back forking hay to my calves, and I'm kind of laid up today. First day I've actually had time to work on the truck in eons, and I can hardly move. ![Real Angry](images/smilies2/mad.gif)
And David, as far as persistent goes... my dad always said you could pi$$ a hole through a rock if you had enough patience, I'm starting to wonder if the hole will ever appear in my 6.0 rock.
And Moe, you are right, I should have checked the most obvious things out first. But I've found I learn lots more if it isn't simple.
![Smilie](images/smilies/happy0161.gif)
#38
So, I took some anti-inflammatories for my back, and they got a big esophagus spasm going, and I'm in worse shape today than I was yesterday. Haven't ate or drank anything since last night. ![Blah!](images/smilies2/smilies6.gif)
But I did find enough energy to find which side has the leaking injector, it's the drivers side. And it appears to be only one injector, judging from the bubble pulses.
I watched Anthony's u-tube video, and was stressing on how to cap the fuel bowl during the test, I have nothing that fits and I'm 30 miles from town, then I discovered the fuel barely seeps out, so I ended up just cracking the line fittings, and that was good enough to pinpoint it.
Good news is, I have 4 seal kits left over from my top injector o-ring fiasco a few years back, so I think I'm just going to pull all 4 injectors rather than mess with the glowplugs.
I just need to start feeling better so I can work on the thing... I'm actually looking forward to it.
#39
#40
Ok, I had a breather and calmed down. A bit. One of these things was obviously leaking - it was putting bubbles back in the fuel bowl. I'm going to emery cloth the injector ends, (there are some carbon spots on them), re-o-ring and washer them, blow the bolt holes and cups clean, and torque them to 26lbs/ft this time. And get ready to trade it off if it doesn't work... I've just about had enough. Going on 7 months without the truck.
Don't worry, I won't go Dodge or "shudder" GM, I'll probably go right to the 6.7 or maybe go gas.
Or maybe I'm just tired and sick and over reacting and I'll keep it when I calm down and feel better.
![Stick Out Tongue](images/smilies/tongue.gif)
#41
John,
Do you have one of the hand vacuum pumps?
Find some hose and see if you have an injector
that leaks down faster than the others. Just
stick the nozzle into some snug vinyl tubing
and a tiny hose clamp.
BTW I checked and you only 14hrs away from me.
Just a bit closer and I would have to see about a
road trip.
Sean
road trip.
Sean
#43
#45
One way to pin down the offending injector is to remove all of the glow plugs and with all of the injectors installed, install one glowplug at a time and do the bubble test, when you come to a cylinder that creates bubbles during the test remove that glowplug and continue the test until you've hit all 8 cylinders.
