Ok, heres the lowdown
1991 ranger 2.3
Driving along, truck lost power. No pops backfires, pings, nothing, engine just smoothly turned off as if it was turned off
at the ignition. Check it out. Timing belt is broken. Tow truck home, remove old timing belt, align crank and cam according
to book, replace timing belt. All good so far right? Nope, truck still wont start. Absolutely no spark at the coils. Here is
everything I have tried since then.
Fuel pump is coming on, fuel is present at the schrader valve on the fuel rail
Swapped out TFI module...did nada
Swapped out one of the coil packs...did nada
checked all underhood fuses....good
all 3 relays seem to be clicking (pump, eec, and ignition)
pulled ignition switch out from column...seems to be working fine
crank position sensor seems to be working fine (turn over motor by hand and when the gap is closed you can hear the relay
start the pump)
all grounds seem to be connected, (engine, eec, etc)
Truck is spitting out a code 88, which is supposed to mean DIS, spout, or SAW failure.
Any ideas on what to try next.
Do you think possibly the ignition or eec relay is bad even though they are clicking?
Is there some type of fuse, fusable link or relay that I am missing
If the EEC was bad would it give any type of code?
I am curious to understand how the ignition switch works.
4 positions acc, off, on, start right. Logic would tell me if the "on" portion of the ignition is not working, the truck
would turn over but never start right? Is this a possibility.
Thanks for the help everyone. Believe it or not, the problem was the module. My old module tested good at two different auto parts stores(tested about 10 times), and passed every time. As well as buying a new off brand model that didnt work right out of the box. What are the odds? So I was racking my brain thinking I had a problem in the wiring harness or something. After I had checked the whole ignition system for continuity and shorts to ground. Once I determined everything else checked out ok, I knew it had to be the module. So just for the hell of it, I went and bought a second one, the truck fired right up!!
