89 Ranger Ignition Problems. No Spark!
Hey fellas. I really need your help here. My truck has been sitting for entirely too long. Even for a FORD ! I haven't been able to start it for a month now. I can't get a spark from the ignition coils to the plug wires.
It's an 89 Ranger 2.3L EEC-VI DistributorLESS Ignition System. Dual coil packs are both new and working properly. New control module. Fuel pump works perfectly. Have done numerous testing of relays and for shorts. I have extracted the engine codes: 15 and 212
15 is EEC processor ROM test failed.
212 is Loss of Ignition Diagnostic Monitor (IDM) input to ECA/SPOUT circuit grounded
I am not quite positive about the 212 code.
Using my Analog meter the sweeps were in this pattern: II II I II II
As I turn the key the starter cranks the engine, but no spark! The Crank Position Sensor is working properly. So rule that out.
The whole senario started when the secondary igition coil was not firing while the engine was running. I replaced the coil. no change. Then i removed the DIS module to have it tested. It passed the test and i put it back on. I have never been able to start the truck since.
I am using the basic Haynes manual which has been usful to a point. But now i think i need some experiential help.
What are the codes REALLY pointing to ? Do i need a new Electronic Control Assembly?? I would appreciate any well thought out guidence to help fix this truck and get it back on the road.
Thanks, Xoryx
Thanks, Xoryx
sixofspades
33
12-25-2023 10:28 PM
grostig
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
11-04-2015 10:04 PM
sixofspades
02-14-2014 08:23 PM
oneminizut
151
08-26-2013 08:26 PM
Andy_Paul
Electrical Systems/Wiring
07-16-2003 09:30 PM
