Master Cylinder question
Old Oct 21, 2014 | 09:27 AM
johntpr's Avatar
johntpr
I replaced my hydroboost unit about 10,000 miles ago. Today I noticed it was wet under the unit. Only this time, it's not red PS fluid, rather, it is brake fluid. So, I assume the master cylinder is leaking and winding up under the hydroboost unit via gravity. Or at least that's my theory.
Anyway Rockauto lists 2 motorcraft master cylinders.
One is BRMC-26 for Hydroboost
The other is BRMC-27 for speed control.
I have obviously Hydroboost, but also have speed control. Anyone go through this and figure out the right one?
Thanks!
Old Oct 21, 2014 | 02:11 PM
Stewart_H's Avatar
Stewart_H
Have you had, or does your Ex have the cruise control in-line fuse harness recall done?
Stewart
Old Oct 21, 2014 | 02:21 PM
jpr38057's Avatar
jpr38057
Stewart
Do what Stewart says first because that could be your leak. As far as the master cylinder goes, they have all been replaced by the BRMC-27.
Old Oct 21, 2014 | 05:14 PM
johntpr's Avatar
johntpr
Yes, it had recall done. No leaks there
Old Oct 21, 2014 | 05:25 PM
johntpr's Avatar
johntpr
Thank you !
Redfridge
May 27, 2014 10:32 AM
Monte1go
1983 - 2012 Ranger & B-Series
Sep 10, 2010 06:06 AM
dougbrown
May 25, 2010 10:19 PM
fordguy2006
24
Mar 22, 2008 10:09 AM
leonard7613
1997 - 2003 F150
Sep 24, 2004 11:51 PM
