97 F150 Master Cylinder , The Rear Line Has A Fluid Control Valve Screwed Into The Master Cylinder . It Seems To Be Leaking Around The Head Of It . Can I By Pass This And Put My Line Right Into The Master Cylinder Or Do I Need To Put It Back In ? if i reuse it in the new master it will still leak , dont know if i can get the seals for the thing ?
Gee Hemmorrhoid. Some people tried to help.
Asking questions is one way.
My crystal ball is broken and I failed ESP1.
Is this a standard or aftermarket item?
If it is standard issue and you start bypassing or deleting it your butt could be in big trouble if you run over someone and it is discovered you tampered with a safety system.
Can you take a picture of it or do you know how to use a camera?
The proportioning valve is down on the frame so you aren't so smart either.
PURPOSE
The brake master cylinder fluid control valve regulates the hydraulic pressure in the rear hydraulic circuit. It is located on the brake master cylinder and is screwed into the rear most outlet port.
OPERATION
When the brake pedal is applied, the full brake pressure passes through the brake master cylinder fluid control valve to the rear hydraulic circuit until the valve's split point is reached. Above its split point, the brake master cylinder fluid control valve begins to reduce the hydraulic pressure to the rear brakes, creating a balanced braking condition between the front and rear wheels to minimize rear wheel lockup during hard braking.
In case of front brake system malfunction, the brake master cylinder fluid control valve has a bypass feature which allows full hydraulic pressure to the rear brake system.
stuart , Removed by Admin you know you have a . sucks to be you
Reason: smart ass mouth and someday me and you might meet .Hemmorrhoid is a real nice way to start a post but i guess if you all live in the hills and marry your sisters then you don't know about maners
You expect people to wait on the edges of their seat for you to ask a question, then get P.O.'d if you are not given top billing.
I know where my sister comes from, but you seem to be more aquainted with marriage customs than I am.
fte ken , i joined this site to seek help and maybe help others . NOT TO BE CALLED A ROID ALSO THE CHILDISH COMMENTS LIKE SHORTBED LISTED .HE'S A SUPPORTER BUT ALL HE COULD COME UP WITH WAS A QUOTE" FROM ME WITCH WAS TRUE I RECIVED NO HELP " AND THEN HE POSTS LAME . SEEMS TO ME ME THAT YOU HAVE SOME PEOPLE ON HERE THAT NEED TO GROW UP !!!! THIS IS SUPPOSED TO BE A SITE TO HELP PEOPLE AND SEVERAL TIMES I'VE SEE REPLYS TO POSTS THAT START OUT BY BELITTLING THE PERSON THAT ASKED THE QUESTION , ALSO I GUESS ITS OK TO SAY Gee Hemmorrhoid AND BE A SMART BUTT AND POST, My crystal ball is broken and I failed ESP1 AND NOT GET YOUR POST REMOVED . SEEMS TO ME THAT IF STURAT1 WOULD HAVE SKIPPED THE BS POST AND WENT WITH HIS 2ND POST ALL OF THIS COULD HAVE BEEN AVOIDED !!!!!!!!!PS. FTE KEN DON'T BE OFFENED IF I EVER START A REPLY TO YOU BY CALLING YOU A ROID OK ?
That's right I am a supporter. I gladly paid the fee to be a supporter because of all the help I have received and contributed to help keep site around so others can be helped, not have someone come on here and say how this site is no help because someone did not answer your question in the first 5 minutes. Someone tried to help you but you post how fte is no help. What childish comments did I list? All I said was it's lame that you say FTE is no help. That's not childish. Rebocardo was asking if you were refering to your cruise control switch which is a valid question since that was what I thought you were refering to. Not everyone sits here all day long to answer you in 5 minutes. Sorry.
Gee Hemmorrhoid.
My crystal ball is broken and I failed ESP1..
SORRY BUT I THINK THE FRIST PART IS COMPLEATLY UNCALLED FOR AND THE VALVE IS ON THE MASTER CYLINDER .YOUR 2ND POST WAS ALOT BETTER HAD ALL THE INFO I NEEDED AND I THANK YOU FOR THAT , BUT THE JOB WAS ALREADY DONE .
