Died while driving.
Old Oct 20, 2014 | 12:00 PM
ib14a69's Avatar
ib14a69
Died while driving.
Our 2002 7.3 died while on the freeway on saturday. My wife was driving it home. She pulled off to the side of the freeway and said that it was turning over but wouldnt start. She also said that the security light seemed to be flashing really fast.
She googled the possible problems and tried turning the key on then off etc, and then leaving the key on for 10-15 minutes. After she did that it started back up but only ran for less than 1/2 a mile before it died again. That is when I got there and was able to tow it home.
The next day I scanned it and got a p0562 low voltage code. I tried to start it but it was dead and would just click when turning it over.
The low voltage code would make me think the alt or batteries are bad, however it makes me confused how it was able to crank over on the side of the freeway and then start and drive for a little bit.
Where do I start looking for the problem?
Old Oct 20, 2014 | 12:21 PM
JaySVX's Avatar
JaySVX
Man that title could have gone in a few different directions. At least it was just the truck.
Low system voltage would make me think a bad alternator/battery. However that cranking/driving makes it feel like a bad ground maybe? Corrosion on the battery?
Old Oct 20, 2014 | 12:35 PM
ib14a69's Avatar
ib14a69
We've had it for 6 months now. I cleaned both battery posts and cables when we 1st got it. They are still both pretty clean, one + post has a little corrosion back on it now I see.
I just took the battery charger off and tested the batteries and got 13.3 volts. I started the truck and then it fell to 12.3. then after just a little bit it went up to 14.3 volts. turned on the defrost, stereo, and head lights and was still 14.3 volts. I shut down the truck and retested the batteries and got 12.9 volts the longer i held the volt meter on the batteries the more the voltage would drop. I forgot I had left the door open so i shut it and then tested again. This time the volts were going up from 12.5 volts
Old Oct 20, 2014 | 09:00 PM
dchaney71's Avatar
dchaney71
Check the harness going over the valve cover on drivers side. I went through a couple IDMs on mine before I found a short to the valve cover (with help from this forum).
I had the same symptom of random stalls, but I don't remember if I had an engine code. It was worse when it got wet..
I fixed mine by wrapping some mastic tape around the harness.
Also, recently my starter was dragging when it cranked. I cleaned all the connections on the batteries and noticed the power lead on the alternator was showing signs of heat. I took that apart and cleaned it and now it starts like I have new batteries.
I think your low voltage may be a secondary problem. Sounds like a loose connection or a short.
Old Oct 21, 2014 | 06:23 AM
carbon coupe's Avatar
carbon coupe
I read the title to this post and thought, "if he died while driving, how is he posting?"
Have you looked at the cam position sensor? My dads truck used to quit randomly and that was the cause.
Old Oct 21, 2014 | 02:15 PM
Stewart_H's Avatar
Stewart_H
Dying while driving down the freeway can be cause by a lot of different problems.
What are you using to scan for codes?
Moving this to the 7.3L forum.
Stewart
OKeefe73
Oct 16, 2017 05:23 PM
techno101
Jan 17, 2015 09:48 PM
Tanner2255
13
Jan 21, 2014 10:42 AM
1badcj8
Feb 24, 2013 02:06 PM
crosbo
28
Nov 15, 2008 08:11 AM
