Fan sensor dtc
Old Oct 18, 2014 | 01:39 AM
Iaff113's Avatar
Iaff113
Fan sensor dtc
Can't seem to find the part number for a fan sensor. Heading to the duck blind bad don't have a laptop
Old Oct 18, 2014 | 08:09 AM
dannyboy950's Avatar
dannyboy950
There is no actual seperate fan sensor, it is a feed back circuit from the clutch itself.
You either need to check the wireing or the plugin for problems or replace the clutch assembly.
Old Oct 18, 2014 | 09:55 AM
Iaff113's Avatar
Iaff113
Originally Posted by dannyboy950
There is no actual seperate fan sensor, it is a feed back circuit from the clutch itself. You either need to check the wireing or the plugin for problems or replace the clutch assembly.
Ok I'll try this when I get back to the truck. Where does the wiring run from? Or where is the clutch located
Old Oct 18, 2014 | 10:18 AM
dannyboy950
The fan blade is mounted to the clutch assembly. The wire harness runs in one of the stator supports.
One half the harness comes from the clutch itself and plugs into the engine side harness.
It kind of snaps into the support member. Sometimes it works out and the fan eats the harness.
Vonnie1969
Aug 30, 2017 11:13 AM
Royson12
Jul 17, 2017 09:42 AM
Shawn93
Jun 22, 2015 01:25 AM
egregg57
May 27, 2013 05:44 PM
gairforce1
Sep 22, 2011 09:37 PM
